Adjusting headlights - Mustang Evolution
Old 09-16-2014, 12:20 PM   #1
rollo1987's Avatar
Ok so I have these nice clear headlights tht came with the car when I got it. Don't know which ones they are. But dam I car see at night. They were missing a clip I eah side and I replaced them. But they seem to still be pointed down. What else can I do to adjust these lights to see better at night.
rollo1987 is offline   Reply With Quote
Old 09-16-2014, 01:03 PM   #2
99_GRUMPY_GT's Avatar
Can you move the headlight by grabbing them with the sliders in place? If the headlight is firmly seated without movement there is not much you can do. But if the slider pin is worn or the headlight is worn in the slider rails, then you can use a small wooden wedge to insert inbetween the headlight and the slider pins. If the lights are pointed downward, then slip the wedge at the bottom, if the lights are pointed upward, then you slip the wedge in the upper side of the slider pin. I have used frozen popsicle sticks to use as a wedge
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-16-2014, 02:13 PM   #3
There is an adjuster on the top of the head light to adjust the vertical aim (up and down). You just use a screwdriver.
In the owners manual, you should be able to find the specs to adjust them properly.
Old 09-16-2014, 02:20 PM   #4
rollo1987's Avatar
Ok great. I will check that out when I get off of work. Thanks
Old 09-16-2014, 03:07 PM   #5
Yeah tonight when its dark out pull rite up close to a wall or building so that you can see where the lights are aiming, pop your hood and on top of each light is a screw u turn to aim them up or down. Adjust them until they look good to you and your done.
TurboCobra is offline   Reply With Quote
Old 09-16-2014, 03:35 PM   #6
rollo1987's Avatar
Awsome thanks
Old 09-16-2014, 04:07 PM   #7
where is this screw, I never have seen it?
Old 09-16-2014, 04:29 PM   #8
on the headlight assembly. on the top, may be recessed a bit in but look and you will find it.
Old 09-16-2014, 05:05 PM   #9
Huh, learn something everyday. My wife continually accuses me of looking at porn because I am on the computer so much. Now I can go and show her my screw that I never knew I had. That aught to show her that porn is not the only thing on the net.
Old 09-16-2014, 05:20 PM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
You can see the adjuster pretty clearly in this pic. It's on the back of the headlight, near the grill. Sholud just need a philips screwdriver.
2012 Kona Blue 3.7L V6:
Old 09-16-2014, 05:25 PM   #11
rollo1987's Avatar
Name:	ImageUploadedByMustang Evolution1410909820.486619.jpg
Is it that. That little circle there is a screw there. On the side of the light
Old 09-16-2014, 05:32 PM   #12
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yep. That's it.
Old 09-16-2014, 06:20 PM   #13
Originally Posted by rollo1987 View Post
Attachment 166255
Looks like in that pic you have taken your stang thru the mud.
Old 09-16-2014, 07:58 PM   #14
rollo1987's Avatar
That was when the radiator cap failed
Old 09-16-2014, 11:04 PM   #15
rollo1987's Avatar
Worked perfectly. Thanks everyone
need help with adjusting headlights to RHD traffic AlpineCY 2005-2010 Mustang GT 3 03-07-2012 10:56 AM
Adjusting Idle and Timing sonicpony03 Pre-2005 V6 Mustang 1 07-23-2008 08:14 PM
adjusting the carb on an 82 GL? I_luv_HP&trq Pre-2005 V6 Mustang 8 09-28-2005 12:14 PM
adjusting the clutch? Murph00 Pre-2005 V6 Mustang 4 01-27-2005 05:02 PM
?adjusting the cam position sensor? Horse Pre-2005 V6 Mustang 24 10-18-2004 06:01 PM
04:13 AM
