2" drop and tower brace - Mustang Evolution
Old 09-20-2014, 02:40 AM   #1
to_oaxaca's Avatar
Region: Nevada
So I purchased Tien Lowering Springs; and Im kinda of a noob when talking about this. When installing what other parts would be necessary or recommended? Or what kind of service would also be necessary/recommended?
These questions are for both the springs and brace, thanks!
2000 Convertible GT
93 Octane Bama Tune
SR CAI
to_oaxaca is offline   Reply With Quote
Old 09-20-2014, 08:41 AM   #2
Mile high JDF's Avatar
I haven't installed a STB before, but ideally for the springs you're gonna wanna do Shocks/struts Caster/Camber plates, and a bumpsteer kit.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-20-2014, 09:23 AM   #3
CC plates at the very least or you'll be replacing the front tires pretty quick. IMO, if you aren't going to do shocks/struts/cc plates along with the springs its not a good idea.
2000 Mustang GT Steeda #0048
Old 09-20-2014, 09:56 AM   #4
Steve96's Avatar
They are right. Get some heavier duty struts, shocks, and CC plates and then install all at once. You could get away with just doing the springs, struts, and shocks for now. Then add the CC plates later, like within 3-4 months or you will chew up your tires pretty good.
1996 GT
Old 09-20-2014, 10:08 AM   #5
Eh... no, do the CC plates or the tires will get jacked up regardless and the alignment will be totally shot.
Old 09-20-2014, 12:39 PM   #6
You have it completely flipped around. Absolute necessary to have the CC plates first. Then in the next few months it'll be ideal to change the shocks and struts to upgraded ones.
Still the best idea is to do it all at the same time.
Old 09-20-2014, 12:41 PM   #7
99_GRUMPY_GT's Avatar
If the shocks and struts are in good shape and you feel you can use them with the new springs, then do so. Or if money is an issue, then re-use the shocks and struts. But the very least you need new camber /caster adjustable plates, and an alignment. Most of the 2 or 3 post tower braces work with majority of all c/c plates. But if you go cheap on them, then you may run into interference issues with the tower brace, seen that a few times before. But if money is not an issue, then go get new shocks and struts and the plates, and alignment for sure. I happen to do my springs a couple months ago, my shocks and struts were not too long ago replaced by PO and the Tokicos were sufficient. So it is basically a judgement call when it comes to the shocks and struts. Make sure the adjustable plates you get are adjustable foe the amount of drop you are going with, not all plates adjust the same with the amount of adjustment allowed, they do have diffferent tolerances.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-20-2014, 12:48 PM   #8
to_oaxaca's Avatar
Region: Nevada
Alright thanks guys for all your advice! Ima have to save up for the cc plates and the struts ... Oh well.
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Old 09-20-2014, 12:55 PM   #9
Here are the ones I got,and they were just fine, and the price is nice for a good set. Plus if you get ahold of Alex with American Muscle, he will give you a discount code to use with all your purchses, 6% off is the discount value on future purchases. He is usually floating around on this site during the weekdays. Or go to the link on top of our homepage and send him a PM.
http://www.americanmuscle.com/srperf...mber-9404.html
Here is Alex info:
http://www.mustangevolution.com/forum/users/42048/
Old 09-20-2014, 01:03 PM   #10
to_oaxaca's Avatar
Region: Nevada
Here is Alex info:
Yea I just saw those on AM and figured I might as well get those. Would you recommend getting the KYB Shock and Struts? Its my cheapest option.
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Old 09-20-2014, 01:39 PM   #11
2000 Convertible GT
93 Octane Bama Tune
SR CAI
For me personally, when a dropping a car like that I would not recommend cheaping out on your suspension components. I would recommend going with the Maximum Motorsports caster camber plates over the SR springs. For your shocks/struts I would look to see if they're designed to handle a drop like that
Old 09-20-2014, 01:41 PM   #12
to_oaxaca's Avatar
Region: Nevada
Yea true, Ill just have to ask if they are designed for that kind of drop. How about used Shocks and Struts?
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Old 09-20-2014, 01:52 PM   #13
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Used shocks and struts are generally hit or miss, I try to avoid them as much as possible. To help with strut choice you can check out this link: http://www.maximummotorsports.com/te...ing_rates.aspx
Just find their recommended springs that match close to your drop and spring rates.
Old 09-20-2014, 01:53 PM   #14
to_oaxaca's Avatar
Region: Nevada
Thanks! Ill check it out
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Old 09-20-2014, 03:04 PM   #15
XSlashDashX's Avatar
Cc plates first lol or your tires be like this.
ID:	166549   Click image for larger version
Old 09-20-2014, 05:50 PM   #16
to_oaxaca's Avatar
Region: Nevada
Damn, that looks really bad
2000 Convertible GT
93 Octane Bama Tune
SR CAI
Old 09-21-2014, 12:59 AM   #17
Steve96's Avatar
I did my plates about 3 months after my drop and had no issues at all with un even tire wear.
1996 GT
Old 09-21-2014, 01:00 AM   #18
Steve96's Avatar
Then again I don't DD it either.
1996 GT
Drop or no drop OzzyLiriano 2011-2014 Mustang GT 15 12-10-2012 01:04 PM
"Damn cops" and "Damn women drivers" fast64 The Bar 10 11-27-2003 08:18 PM
My painted Valve covers and Strut tower brace Danger Dude Mustang Audio & Video 44 08-10-2003 05:58 PM
03:03 PM
