need help car feels sloppy - Mustang Evolution
Old 09-23-2014, 06:53 AM   #1
samcrored's Avatar
did upper and lower control arms...but still the rear end feels sloppy, also normal take off gives me a bad shake in the car and you can feel it in the shifter..almost like its wheelspin and it just cant grab the road, but also similiar to clutch chatter. but when im on fresh pavement iand take off normally i can hear the little squeels from the tires ...i have no idea what it is and its about to make me sell the car
samcrored is offline   Reply With Quote
Old 09-23-2014, 01:23 PM   #2
99_GRUMPY_GT's Avatar
What control arms did you buy? And as I found out from another trusted source the uppers should be left OEM, just replace the bushings. Reason being the aftermarket uppers with their stiff bushings cause so much strain to the torque box that it can not hande that kind of stress and causes the torque boxes to break away. You can buy a torque box reinforcement kit for using new aftermarket UCA. If you go with a torque arm and pan hard bar, then you can get rid of the uppers all together.
What was the reason for the new control arms prior to this? And please give a better explaination of what you are experiencing with the rearend.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-23-2014, 01:29 PM   #3
The stock suspension in these cars are terrible. In this order is what needs to be done to them for good handling:
1. Subframe connectors
2. Rear Lower Control Arms
3. Panhard Bar
4. Torque Arm.
5. Springs/shocks/struts (or coilovers)
6. Sway bars (these depend on how you drive the car)
Sloppy Steeda Triax shifter InfinibandGT 2011-2014 Mustang GT 20 03-29-2014 09:13 PM
sloppy steering on the highway. 94gtconvert 1979-1995 Mustang GT 9 03-02-2014 09:24 PM
Quick fix for sloppy MT82 shifter 2013_DIB_GTCS 2011-2014 Mustang GT 4 07-14-2013 10:42 PM
Creaking & sloppy steering wheelman 2005-2010 V6 Mustang 4 02-16-2012 11:31 AM
What It Feels Like To Need Sex All The Time Brent The Bar 3 07-18-2007 06:44 PM
01:21 AM
