Squeek at left rear wheel - Mustang Evolution
Old 09-25-2014, 05:05 PM   #1
fomoco4life's Avatar
I took a hard curb shot a while back (popped tire, totalled rim), now whenever that tire hits a bump, I get a squeek, any idea what would cause squeek on only one side
Old 09-26-2014, 07:20 AM   #2
Just on bumps? No noise dependent on wheel speed or anything that would be a bearing? If its just a squeaking over bumps, jack your car up and crawl under there and inspect stuff. You likely goobered something up in the suspension on that side when you smacked the curb. Could be as simple as an isolator, could be something more serious like a broken spring or the shock got knocked out of the bracket on the rear axle or something along those lines.
2000 Mustang GT Steeda #0048
Old 09-26-2014, 07:58 AM   #3
99_GRUMPY_GT's Avatar
Might of screwed the axle bearing since he stated he popped the tire and destroyed the rim.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-26-2014, 09:23 PM   #4
rollo1987's Avatar
I have the same issue on my car. Was going to swap out axles when I change the diff gears.
rollo1987 is offline   Reply With Quote
Squeek coming from drivers rear 10cches 1996-2004 Mustang GT 6 08-08-2012 01:50 AM
Weird squeek coming from the rear Whitestang93 Pre-2005 V6 Mustang 13 05-05-2012 06:19 AM
Clutch Squeek?! pringle9666 Pre-2005 V6 Mustang 4 07-14-2011 05:24 PM
fixed the squeek epd418 1996-2004 Mustang GT 3 07-13-2010 11:04 AM
squeel/squeek epd418 Pre-2005 V6 Mustang 4 07-06-2010 05:29 AM
05:44 PM
