2001 Bullitt Throwing Out Coolant - Mustang Evolution
Old 09-26-2014, 06:52 PM   #1
TheBullittTeam's Avatar
Hey guys Were New To Fourms Just Bought Our Project Car On The Quest for 10s!
We have An Issue With the Car Overflowing Coolant When we Get on it The Car is Not overheating Its Not Throwing Any CheckEngine Lights we Just Did a full service For New Coolant new Plugs New Coil Packs And New 19lb Injectors
When we bought the car
Then we drove it home Powershifted AfewTimes and it was overflowing woth coolant we put a new Reservoir cap thinking its not holding pressure that dident work took it to local Performance shop and he said its not the thermostat havent took the car back to Testing yet any1 have any ideas? What it could be seems to only
Happen when we get on it
TheBullittTeam is offline   Reply With Quote
Old 09-26-2014, 06:57 PM   #2
where is it puking out of?
TurboCobra is offline   Reply With Quote
Old 09-26-2014, 07:00 PM   #3
Its flowing outta the coolant reservoir but the car is not overheating
Old 09-26-2014, 07:46 PM   #4
Mine does that if I over fill the reservoir.
Have you tried letting it "puke out" and then NOT adding any additional coolant and then trying another WOT pass?
Old 09-26-2014, 07:50 PM   #5
No But the OverFilled Makes Sence were Outta Town till Monday I have a appoiment with my Local Mustang Specialist performance shop On the way there i said ill
Just get on it afew Times hitting 1-3 and see what happens from There ... Im new to sites is there a way we can add eachother as like a friendslist? Nice to Talk with Other Bullitt Owners!
The PowerShift Team.
Old 09-26-2014, 08:07 PM   #6
Yes! And welcome!
It's nice to have some more Bullitts in our ranks. There's a thread in the "Special Edition" forum titled "Let's See Your Bullitt", post some pics when you get a chance.
The reservoir doesn't need to be over filled by too much for it to overflow. Hopefully, that's all there is to your problem.
Old 09-26-2014, 08:14 PM   #7
I will post once shes all Fixed up with The Welds And Cowl Hood and Some Window Decals! Nice meeting you buddy
Old 09-27-2014, 07:55 AM   #8
99_GRUMPY_GT's Avatar
Could this be a burping issue? Air in the coolant system?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-27-2014, 12:39 PM   #9
We did a pressure test it held at 16psi
Old 09-27-2014, 04:04 PM   #10
1. Did you replace the cap with an OEM from Ford? Don't use a Stant or aftermarket cap. The parts guy will likely swivel in his chair and grab it from the shelf behind him because it's a high failure item. Same cap used on Ford trucks BTW.
Make certain the threads on the coolant tank aren't stripped. That's one reason why you don't use an aftermarket cap except in an emergency. The ones I have seen do NOT have the tighten till it clicks and slips feature and people tighten them down like the hammers of hell and strip the threads on the tank.
I just replaced my cap and it was like $12.00 from Ford. Mine was seeping.
Make sure the rubber gasket on the cap is free from debris and the old rubber gasket from the old cap didn't get stuck on the coolant tank.
Boiling over coolant is almost always either a blockage or overheating.
Put the front of the car up on jack stands or ramps, take the cap off the coolant resovoir and run the car until the thermostat opens. Squeeze the radiator hoses and "burp" the baby
If that doesn't work, just as a test, take the thermostat out and run the car without it.
If you still have problems, then you are looking at a blockage which is probably in the radiator.
One last thing, I'm not sure if this is even possible on the Mustang but make sure the hoses are not reversed.
I had this on a Volvo and it drove me nuts.
It was actually possible to reverse two hoses and the coolant was flowing against itself causing this exact problem.
Keep us posted!
vert03 is offline   Reply With Quote
Old 09-27-2014, 04:11 PM   #11
Yeah we had it replaced with a oem cap he had laying around cause the old cap wasent holding pressure im positive the hose aint reversed it could be a blockage in the radiator ima go ahead and do a 170 thermostat just for save measure since shes gonna need it Down The Line When i Add The UpComing Mods im sure its somthing minor or could just be the Coolant reservoir it self cause car is not overheating ima post a video of it In a Few Mins Just to show whats going on with it thanks for all the helps guys!
2001 Cobra throwing codes Slow4V 1996-2004 Mustang GT 1 11-29-2013 06:34 PM
I'm throwing it downfield. bullitt482 The Bar 11 02-07-2007 06:36 PM
Throwing fuel on the immigration fire... Seph The Bar 29 05-02-2006 03:59 PM
03:16 PM
