Need your help - Mustang Evolution
Old 09-26-2014, 07:44 PM   #1
BlackstangGT's Avatar
Need your help
Brake light lamps are stuck on my 2003 mustang gt
BlackstangGT is offline   Reply With Quote
Old 09-26-2014, 07:45 PM   #2
Mfore33's Avatar
Check the brake light switch behind the brake pedal.
Old 09-26-2014, 07:47 PM   #3
Where behind the peddle and is it a certain color because I tried looking but couldn't find anything
Old 09-26-2014, 07:52 PM   #4
Mfore33's Avatar
Here is a YouTube video of it.
Old 09-27-2014, 08:14 AM   #5
99_GRUMPY_GT's Avatar
Mfore33, that youtube video does not work.
Have you tried taking your foot or your hand and pull up on the brake pedal to see if the brake lights go out? If that happens, then you should take some lithium grease or WD40 and spray the brake arm up at the top were the pin is located. If that is not the issue, then most likely the brake switch is faulty and needs replacing. It is located straight up the brake arm with I think 2 wires going into the switch. But try the pulling up on the pedal first as it may just be a sticky pedal.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-27-2014, 09:33 AM   #6
Took it to the shop today they said it's probably the fuse so hopefully that's all the problem was but thank you for the help
Old 09-27-2014, 10:14 AM   #7
Mfore33's Avatar
Sorry about bad link
Old 09-27-2014, 12:09 PM   #8
If the fuse was bad, then the brake lights would not come on at all. Since they are lit as you say they stay on the entire time, then that tells me that the fuse is ok.
Old 09-27-2014, 12:43 PM   #9
Got it fixed something with the sensors and switch
take off your hat and place your hand over your heart. Seph The Bar 10 12-07-2004 05:48 PM
I need your help! acidkoolz The Bar 10 07-13-2004 05:39 PM
techie guys, I need your help fast64 The Bar 2 04-30-2004 08:35 PM
Need your help, gt takeoffs or flowmasters? GuRu Pre-2005 V6 Mustang 25 04-06-2004 09:20 PM
Any lawyers out there?!?!?! I need your help!!! fast64 The Bar 10 07-23-2003 07:27 PM
08:16 AM
