Aviator 4v swap - Mustang Evolution
Old 09-27-2014, 12:23 PM   #1
Roguestang's Avatar
Aviator 4v swap
So, I've been kicking around the idea of the coyote swap, or a 4V for my 2000 GT. This thread isn't about what should or shouldn't I do, because as luck would have it I bought an entire 04' aviator for cheap from a buddy of mine. I've heard it done before, but never really found a specific write up or answeres to my questions. So I did a ton of research, and I've got a pretty good idea what I need to do. But as we know, something like this may have alot of little things to adapt. Unfortunately I will be out of town for the next month for work, but sometime in November I plan on doing the swap (assuming I don't run into any big issues). I'll keep updates for those that might be interested in the project!
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-27-2014, 02:08 PM   #2
Mile high JDF's Avatar
Is it a 4.6 4V or a 5.4 4V? I'm looking forward to updates
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-27-2014, 02:30 PM   #3
99_GRUMPY_GT's Avatar
It has to be the 4.6 4v, as it was the only engine available. Aviator's did not have an option for a 5.4 4v.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-27-2014, 03:38 PM   #4
Roguestang's Avatar
Yeah its a 4.6 4v. It's the exact same long block as what is in the 03-04 mach 1's.
Old 09-27-2014, 03:41 PM   #5
Roguestang's Avatar
I'm gonna try to keep the aviator intake too, since I've got a hood to clear it, and I can rig the imrc valves to open.
Old 09-27-2014, 04:57 PM   #6
Ah ok , it was the Navigator that got the 5.4 then correct?
Old 09-27-2014, 06:38 PM   #7
You got it, the Aviator was the sister of the Navigator
Old 09-27-2014, 07:33 PM   #8
Roguestang's Avatar
And to be clear, the aviator has a 6 bolt cast crank. So it's the same as the 03-04 mach 1 with an auto tranny. I'm going to go with some Longtubes and obviously a tune afterwards. So assuming I can get the intake imrc's to work, I'm hoping to be around 300 rwhp.
Old 09-28-2014, 02:21 PM   #9
Cool!
I look forward to following along.
Old 09-28-2014, 02:33 PM   #10
Roguestang's Avatar
I bought some small odds and ends I know I'm gonna need yesterday and today. Also figured I'd do my rear brakes as the pads are getting low.
Old 09-28-2014, 06:52 PM   #11
Good deal. Cast crank is fine if you keep it under 7k. I'd just delete the IMRCs, completely not needed on a Mustang. Keep us updated.
Old 09-28-2014, 07:35 PM   #12
Do you know what cams those aviator 4.6's have? Depending on the cam profile you may want to swap in some 96-98 cobra cams before you drop her in. Pick up a fee more ponies and gain some low end grunt.
Old 09-28-2014, 10:15 PM   #13
Roguestang's Avatar
Thanks guys! The Aviator intake is similar in theory to the fr500 intake. So the imrc's are controlled by a stepper motor. I'm gonna try to hook em up, but if not I was going to wire them to stay open. I forget where I saw it, but there was a shop that did a few of these swaps and they all kept the imrc open too. And the cams are the same as the 99-01 cobra, and 03-04 mach 1. I thought about grabbing some 96-98 cobra cams, but I don't really want to deal with setting the timing up. My plan was to not have to Crack it open at all.
Old 11-14-2014, 08:34 PM   #14
Roguestang's Avatar
Well, got the 4v out of the aviator today. It was a total PITA since you're really suppose to lift the body off the frame, but nobody got time for that. A Sawzall and torch did a decent job of getting the front end off.....
ID:	169723   Click image for larger version
Old 11-14-2014, 08:35 PM   #15
Roguestang's Avatar
I also got my headers in finally, and on Monday I'm going to work on getting the 4v ready to drop into my New Edge (still gotta pull the 2v outta her).
Old 11-20-2014, 07:13 PM   #16
Roguestang's Avatar
Another update: swapped a mustang oil pan and mach 1 oil pick up tube onto the 4v. The 4v pick up tube is just and tad bit bigger than the 2v (see pics ). And the 2v tube will bolt up, but it's lose. Installed new motor mounts and deleted the egr (yes I'm getting it tuned). Also I'm using the aviator thermostat housing.
ID:	169990   Click image for larger version
ID:	169992   Click image for larger version
Old 11-20-2014, 07:25 PM   #17
Roguestang's Avatar
I also used my GT throttle body (I have a bbk 75mm). All you have to do is turn it upside down and it'll work fine. I was finally able to use the lift today and was able to pull the old tired 2v out. Man was it dirty! I pulled the tranny out with it and I'm swapping in a tubular k member with the 4v and longtubes. I will be using my stock a arms, with spring perches.
ID:	169995   Click image for larger version
ID:	169997   Click image for larger version
ID:	169999   Click image for larger version
Old 11-20-2014, 10:34 PM   #18
V6 stang's Avatar
Looking good so far. Can't wait to hear about the results. How many miles did the 2v have?
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 11-22-2014, 09:29 PM   #19
Roguestang's Avatar
That 2v had over 250k on the short block. The rings were shot, and blowing smoke as you can see from how dirty it was. Lol today I installed brand new poly bushings in the a arms, and hacked up the 2v harness a bit. I have the factory Aviator harness, so I took the connectors for the COPs off that and I'll be splicing them into my harness. The good news is, the wire colors are the same from my harness to the 4v, so it's going to be pretty easy. Match the colors, and since I'm using the 4v connectors, I don't have to worry about reversing the polarity. Plus it'll look stock. I'll also have to splice In the 4v alternator connector, but again since it's from the 4v harness, it's a simple splice. I ordered a King Cobra clutch, and resurfaced my flywheel. I also got a new hydrobooster since mine was leaky, and nows a good time to imstall it. I have to go back to work on monday, so the next time I'll be working on her will be next saturday. Just have the wiring and suspension left to put together. And then it'll be almost complete.
ID:	170119   Click image for larger version
Old 11-29-2014, 04:44 PM   #20
Roguestang's Avatar
Worked on the suspension alittle today. Put new poly bushings in the a arms, and bolted them up to my UPR k member. Let me take a moment to say that the stock a arms will bolt up, however, I ended up grinding down the front of the most forward facing bushing. This allowed them to slide in with a little persuasion...lol also installed new inner and outer tie rods for the steering rack.
ID:	170505   Click image for larger version
ID:	170507   Click image for larger version
Old 11-29-2014, 04:47 PM   #21
Roguestang's Avatar
Also, my car is sitting below the immortal Hulk Hogans Charger
Old 11-30-2014, 11:28 AM   #22
Billgluckman's Avatar
Hulk hogans? Lol
Good stuff man. Pretty sure I'll going 4v later on.
Billgluckman is offline   Reply With Quote
Old 11-30-2014, 11:37 AM   #23
Roguestang's Avatar
Lol yeah. I'm in Tampa, and the shop I'm at has been working in his cars for years. It needs new carbs.
Old 11-30-2014, 11:57 AM   #24
That's awesome lol
Old 12-14-2014, 07:25 PM   #25
Roguestang's Avatar
Just a quick update, installed a new hydrobooster as mine was alittle leaky. But next week, I'm gonna start putting the 4v in the car.
Old 12-20-2014, 07:29 PM   #26
Roguestang's Avatar
My buddy decided to do the wiring this past week, so unfortunately I wasn't able to get any pictures during the process, but I have the finished product:
ID:	172292   Click image for larger version
Old 12-20-2014, 07:30 PM   #27
Roguestang's Avatar
He wired them into the 4v harness, and the cables are all the same colors between 2v and 4v, so it's really not that hard. Next up is the clutch install and tranny. Headers, then she'll be good to go back in the car!
Old 12-20-2014, 07:39 PM   #28
You make it look so easy!
Old 12-20-2014, 07:41 PM   #29
Steve96's Avatar
Looking great!
---------- Post added at 09:41 PM ---------- Previous post was at 09:41 PM ----------
Good Xmas present to you! A fresh 4v
1996 GT
Old 12-20-2014, 07:46 PM   #30
Roguestang's Avatar
Haha if only it was. Dont get me wrong, it's not a hard swap. Some do it in a weekend. But I added alot of new and aftermarket parts. And trying to do it while working my full time job. It's been dragging on alittle longer than I had hoped for, but at least I know it's being done right the first time.
Old 12-20-2014, 07:47 PM   #31
Roguestang's Avatar
Looking great!
Lol it probably won't be done by Christmas, but I'm going out of town for work in mid January so I hope to have it running by then.
Old 12-20-2014, 09:50 PM   #32
Steve96's Avatar
Either way you have made some good progress. Sometimes I wish my engine would go so I could do a swap, lol. I guess I could but I don't have enough motivation.
1996 GT
Old 12-21-2014, 01:09 AM   #33
phillip433's Avatar
Yea... I was just saying that to myself as I was reading this post. I never did do my t56 swap unless my tranny went out. I wanna do a coyote or a 4v swap whenever my engine goes.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 12-21-2014, 06:37 AM   #34
ultrawhiteSN95's Avatar
Any lincoln Mercury Ford engine will fit , since they are the same motors
Only thing you will have to do is keep the aviator wiring harness
and that should safice , wiring harness is basicallythe main thing in any engine swap
1998 GT, Edelbrock Victor Jr. Ford 4.6L SOHC, Edelbrock Fuel Rails, 1999 Gt Engine w/ PI Heads,Accufab 70mm TB & Plenum,Fuel Pressure Regulator 515 Series Inline Return Style, 25-90 psi, Underdrive Pulleys,MSD ignition coils ,4.10 gears,Diablo Sport Predator Tuner
ultrawhiteSN95 is offline   Reply With Quote
Old 12-21-2014, 07:33 AM   #35
Roguestang's Avatar
Just keep a lookout in your local craigslist and junkyards. Then if you find a 4v (out of any of fords brands like ultrawhite mentioned), grab it up. The best time to do this swap would be while your current engine is good, that way you won't be rushed for time, or if you have another DD. Luckily for me both those apply, so I can afford to do it right. Otherwise, you'll cut corners, and/or get inferior parts, and that will most definitely come back to haunt you later.
4v Swap from aviator bluegt96 1996-2004 Mustang GT 24 06-09-2014 06:32 PM
To Swap, or not to swap...... Strongarm 1979-1995 Mustang GT 5 02-05-2008 01:39 PM
Engine Swap ERICK Pre-2005 V6 Mustang 10 02-21-2006 07:46 AM
Best Aviator Contest..possable *WW* drummerstang98 The Bar 11 08-17-2004 11:06 PM
07:42 AM
