tune up - Mustang Evolution
Old 09-27-2014, 05:04 PM   #1
tune up
Compression test
clean or replace fuel injectors
new spark plugs
new coils or boots and springs
under drive pulleys
new belt
clean MAF sensor
replace PCV valve
replace IAC
test alternator
test battery
clean throttle body
new vacuum lines and hoses
coolant flush and fill
oil/filter change
air filter change
02 Sensors
EGR Valve
can anyone add to my list of things to do/replace to help with freshening up the engine.
TurboCobra is offline   Reply With Quote
Old 09-28-2014, 12:37 AM   #2
That list looks pretty complete! Throw in a trans and diff service and you've done pretty much all that you can do until something wears out or breaks.
The only additional thing that I did on my car is replaced the upstream 02 sensors. They both still worked but my car is getting along in miles and I don't like it when stuff breaks.
Old 09-28-2014, 10:31 AM   #3
I will add the 02 sensors to the list. I was thinking about changing out some of the other sensors and the egr valve as well
Old 09-28-2014, 05:20 PM   #4
99_GRUMPY_GT's Avatar
Check your swaybar end link bushings, and your balljoints and tierod ends. Throw a can of SeaFoam in the tank. Check tire pressures, brake pads and rotors. U-joints, check and replace if needed. Power Steering fluid flush and re-fill, and replace brake fluid. You be surprised hell much better a brake pedal feels with newly flushed brake fluid and re-fill.
Forgot to mention, Blinker fluid, and headlight flint level. Replace the flint as needed.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
hybrid tune vs. race tune 13 stang22 2011-2014 V6 Mustang 37 03-30-2013 09:38 PM
to tune or not to tune.... rebeltx 2011-2014 V6 Mustang 24 01-02-2013 11:46 AM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 11:45 AM
Question on installing Bama tune if previous tune already loaded on car ljn21 2011-2014 Mustang GT 7 08-01-2012 11:08 AM
To tune or not to tune? grossnickle6612 2011-2014 V6 Mustang 10 08-24-2011 10:27 PM
10:14 PM
