painting Rad - Mustang Evolution
Old 09-28-2014, 12:17 PM   #1
painting Rad
Saw some paint in the auto isle for Radiators.
Has anyone on here ever painted there rad? was thinking it would look really good black with the mach 1 grill delete.
TurboCobra is offline   Reply With Quote
Old 09-28-2014, 12:44 PM   #2
Isn't the A/C condenser in front of the radiator?
Old 09-28-2014, 01:19 PM   #3
yes it is haha can that be painted as well?
Old 09-28-2014, 01:33 PM   #4
99_GRUMPY_GT's Avatar
I painted mine a few yrs ago in my Bronco. Also had the external trans cooler in front also. I painted the rad black and the trans cooler red. The painting is a good appearance touch, but just remember to paint it is light coats so to not over spray the cooling fins and clog them up to prevent air flow. I also put a laydown of Ford lettering to paint over so that the ford showed up throught the grille, The middle section I painted Blue and the over lay in black. Turned out nice. But it is better if you throughly clean the rad of any corrosion and oil residue. Also, for better adhesion, prime coat it first.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-28-2014, 01:35 PM   #5
Yeah that's what I was wondering about, If spraying it would cause any clogging and if there's anything specific I need to do
Old 09-28-2014, 02:15 PM   #6
The only downside to painting the condenser is that the paint will act like an insulator of sorts so that will decrease the efficiency of the condenser by a bit. If you do it, do like Grumpy said and just apply enough paint to give it some color and that's it.
Old 09-28-2014, 03:31 PM   #7
Might car mods says that If you paint your intercooler black that it will make the air flow cooler
Old 09-28-2014, 10:12 PM   #8
I always heard that if you paint an engine block black that it will run hotter.
I believe that they are myths and if there is a difference between colors it is so slight as to be barely perceptible.
With the exception of something that is exposed to sunlight, of course, then a flat white is best for its ability to reflect the light and maintain a cooler surface.
Rad choice? Leo92lx 1979-1995 Mustang GT 3 02-10-2013 04:49 PM
Tips on cutting rad cover for hood pins? maverick214 2005-2010 Mustang GT 4 01-10-2013 06:59 PM
Need help rad fluid everywhere! Dyllan 2005-2010 Mustang GT 2 10-06-2012 11:54 PM
06 GT rad fluid question Dyllan 2005-2010 Mustang GT 8 10-05-2012 06:22 PM
HUGE SALE : cobra lights, corners, rad shroud, amp, 2 core INTERCOOLER, cam etc!!!! Autobadges.com Mustang Parts for Sale and Wanted 0 08-06-2006 11:55 PM
09:00 PM
