Strange electrical issue - Mustang Evolution
Old 09-29-2014, 05:48 PM   #1
Tpbluegt's Avatar
My gauges reset and I lose all power while driving intermittently. I've noticed it tends to do it when I accelerate quickly but is fine when idle or slow rolled..any info would be greatly appreciated
Tpbluegt is offline   Reply With Quote
Old 09-29-2014, 05:48 PM   #2
Mile high JDF's Avatar
Have you gotten an alternator load test done?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-29-2014, 05:49 PM   #3
Tpbluegt's Avatar
No I haven't.. Can I do that without removing it from the car?
Old 09-29-2014, 06:15 PM   #4
Most auto shops should have a machine to test it. Auto Zone I but I don't know for sure. Just to clarify, you lose all power to the car or just to the gauges?
Old 09-29-2014, 07:19 PM   #5
Tpbluegt's Avatar
All power and the gauges reset and then it's good again
Old 09-29-2014, 07:41 PM   #6
I'd start by checking all of the basic things like battery terminals, cables, carefully check the grounds, etc.
If everything looks good, shake all of the battery cables and wiring harnesses, with the engine running, and try to replicate the intermittent power loss.
Old 09-29-2014, 08:38 PM   #7
Battery terminal connections like straybullitt says. Clean an reseat and tighten.
vert03 is offline   Reply With Quote
Old 09-30-2014, 05:36 AM   #8
99_GRUMPY_GT's Avatar
And most inportantly do not forget the grounding areas, look them over, see if the grounding pints are loose.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-30-2014, 06:13 AM   #9
Yep.
Look around the battery and radiator support etc for grounds and make sure they are tight. If any look corroded, take the bolt out, clean up the surface and tighten down again.
The cluster resetting, the gauges going all the way up and then back to normal, means it has at some point lost primary power. Last time I had this it was what seemed to be a tight connection at the battery post but was actually slightly loose.
Start there and work your way back to the junction box. Also make sure all fuses are seated tightly.
Got a strange issue. Mustang 4pt0 General Car Discussion 5 02-25-2014 09:53 PM
Strange Electrical problem TheJigShow 1996-2004 Mustang GT 6 06-25-2012 05:28 PM
Strange Exhaust Issue michael81 2011-2014 Mustang GT 1 05-05-2012 07:23 PM
Electrical issue Seattle66 Classic Mustangs 10 02-24-2012 11:12 AM
Halos/LEDs won't flash! (Strange issue) MarshallYoung 2005-2010 V6 Mustang 4 01-11-2012 11:47 PM
11:52 PM
