3.8-5.4 swap..need some answers - Mustang Evolution
Old 09-30-2014, 02:18 PM   #1
code_cobra911's Avatar
Ok..so a while back I was talkin a little bit about the gt swap I WAS gonna do, but..that got ruined. Stupid mistake I made on my part. Got the motor, bought the accessories and pretty much everything I needed for the swap..then I painted the block. Took the oil pan off and what do ya know..the best present ever..a shattered rod laying in the oil pan and 2 other rods bent. Probably should have been the first thing i looked at. So I ran across a 2001 5.4 2v that I'm going to get for free. It's a complete motor but I'm wondering if the injector wiring harness would match the GT ecu harness. It's coming out of a expedition. And also what size clutch would I need for the 8-bolt flywheel.
code_cobra911 is offline   Reply With Quote
Old 09-30-2014, 02:33 PM   #2
Rapinator126's Avatar
Don't waste your time with that motor. Complete waste and junk.
Good paper weight
Old 09-30-2014, 02:41 PM   #3
You didn't answer either one of my questions..so unless you know the answer, you have nothing to say to me so your opinion isn't needed.
Old 09-30-2014, 10:28 PM   #4
For a V8 conversion, you bolt it in like you would the 4.6L. Exhaust is a little different and you might need a cowl. Pretty much identical otherwise. Its a 99% bolt in and will have more bottom end but not really anything else up top.
What I would do if I were you if feasible is sell your V6 and just buy a GT and mod that. You are going to need the harness, fuel system, trans and a few other things out of the GT anyway. If you are still dead set on the swap, might as well get a donor car to make it easy.
2000 Mustang GT Steeda #0048
Old 09-30-2014, 10:28 PM   #5
Need Answers about 4V swap BigB227 1996-2004 Mustang GT 23 01-30-2014 09:05 PM
Need wheel answers ASAP Lastoria24 Mustang Wheels & Tires 6 05-14-2011 03:32 PM
OMG, someone give me some answers CPL Ahern Pre-2005 V6 Mustang 27 03-25-2011 10:36 PM
Okay you Ford guys need some answers..? riordain General Mustang Discussion 2 03-11-2010 02:59 AM
need feedbacks due to inconsistent answers..C spring cutting tire Pre-2005 V6 Mustang 12 03-08-2004 02:57 PM
11:31 PM
