Cutting Springs - Mustang Evolution
Old 10-01-2014, 02:00 PM   #1
03RedfireGt's Avatar
Cutting Springs
I am replacing the struts so figured it would be a good time to do this. This is my first time tackling this so I have questions about both the strut replacement and cutting the springs. 1st will I have to remove my long tubes? will i have to remove the cat back? will I need a coil spring compressor? Is it just 1 coil off each spring?
03RedfireGt is offline   Reply With Quote
Old 10-01-2014, 02:28 PM   #2
Mile high JDF's Avatar
Let's see:
1. No
2. No
3. Depends in the person, I didn't use one on mine and I had no issues
4. Depends on how low you want to go
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-01-2014, 03:05 PM   #3
5 just buy aftermarket springs.
Old 10-01-2014, 04:59 PM   #4
Roguestang's Avatar
There are literally 1,000's of threads on cutting springs. and you'll see people say it's ok, and people say don't do it. Sounds like the OP is already set to cut them, so do your research, and you'll find your answers. I've been sitting on cut springs since 06' and have never had an issue. Just remember it's easier to cut off a little at a time and test fit, than to try to add a coil back on if it's too short. Lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-02-2014, 08:15 AM   #5
Thanks all. I was looking for the sticky that had the step by step for cutting front an rear springs. Cant seem to find it now. Just seen it a couple days ago.
Old 10-02-2014, 11:44 AM   #6
SVTPerformance has one for the Cobras that should work the same for the most part
Old 10-02-2014, 11:58 AM   #7
Slow4V's Avatar
I've cut mine before lol and friends .. it's okay .. just don't cut more than a coil and a half up front or rear
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-02-2014, 01:55 PM   #8
ok thanks, I found the one from SVT should be very helpfull
Old 10-03-2014, 05:08 PM   #9
Everything you ever wanted to know about spring rates: Cutting Coil Springs, with calculations - EATON Detroit Spring
vert03 is offline   Reply With Quote
Old 10-05-2014, 03:24 PM   #10
Panther140's Avatar
I don't see what is wrong with cutting springs. It lowers your car and stiffens up the suspension, because there is a bigger coil thickness to spring length ratio. Sounds like exactly what stock Mustangs need. Lower and stiffer. Yeah some springs on certain cars shouldn't be cut because of the way the end of the spring is where it mounts, but its fine on fords.
Panther140 is offline   Reply With Quote
cutting springs? BlackSix Pre-2005 V6 Mustang 17 11-24-2008 10:50 PM
cutting springs.. x99xstangxx Pre-2005 V6 Mustang 11 11-07-2007 08:03 AM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 01:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 05:36 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 01:59 PM
06:55 AM
