abs control module - Mustang Evolution
Old 10-02-2014, 04:33 PM   #1
dmcgoy3's Avatar
abs control module
Is there a difference between an ABS Control Module and the Electronic Brake Control Module? I had my car at a shop and they said that the reason my ABS light was staying on was because the EBCM was bad, but they couldn't find one to replace it. Anybody have any experience with this? I've seen a couple repair services online, but I'm a little nervous to send parts in to someplace I've never heard of.
dmcgoy3 is offline   Reply With Quote
Old 10-03-2014, 02:47 PM   #2
thyreaper's Avatar
abs control module
The repair services dont always work my ex boss use to send the ebcm's in to a repair service and they come back throwing more codes then when it went out lol, needless to say he stopped doing it and would find a good used one on ebay or craigslist
thyreaper is offline   Reply With Quote
Old 10-03-2014, 04:00 PM   #3
You need to have the code pulled. Chances are it's a wheel sensor that has a lot of metallic "fuzz" on it or a broken wire to one of them. Get the code and go from there.
Don't just replace parts without a diagnosis.
vert03 is offline   Reply With Quote
Old 10-03-2014, 10:54 PM   #4
Mfore33's Avatar
I was told that my abs unit was bad by three different shops. Each one tried to pull codes and said that the abs unit would not connect to their test machine and "talk" to it. If I can't get codes pulled off it must be the bad module that is bad but ford doesn't make them any more. So I guess I will just not have anti lock brakes any more.
Old 10-04-2014, 05:18 PM   #5
thyreaper's Avatar
Yes u can, look to ur closest salvage yards they will have one from a mustang that will work im sure, call around i would not just let it go and not have abs, here where i live we have yearly state inspections and if your red brake light is coming on with the yellow abs one ( which sometimes they do) it will fail inspection
Old 10-05-2014, 06:37 AM   #6
If they can't pull the codes, assuming it's not a wiring problem or a fuse, then I would say the module is toast. Like thyreaper suggested, try the salvage yards.
ABS Light Bad Module TheJoeBailey 1996-2004 Mustang GT 1 05-02-2014 03:53 PM
Abs module needed Mfore33 1996-2004 Mustang GT 4 04-12-2013 06:31 AM
Do i need new abs module? Mfore33 1996-2004 Mustang GT 5 04-06-2013 09:59 AM
Mach 1 ABS module help! DaBluedude SVT Mustang 11 11-07-2011 06:48 AM
Help quick! Abs module! CHILE10_STANG Pre-2005 V6 Mustang 3 09-02-2010 10:14 AM
04:14 PM
