E brake light - Mustang Evolution
Old 10-05-2014, 04:59 PM   #1
robin_gt's Avatar
E brake light
Hi folks so since the past week i started noticing that SOMETIMES when i brake the e brake light comes on for like 1-2 sec. Should i be worried? Its a 2002 mustang gt
robin_gt is offline   Reply With Quote
Old 10-05-2014, 05:01 PM   #2
Just add brake fluid, it may look like the level is fine but just add some anyways. That should make it stop! I had the same thing happen to me.
Blackedout03gt is offline   Reply With Quote
Old 10-05-2014, 05:02 PM   #3
robin_gt's Avatar
Thanks for the quick response ill give it a try.
Old 10-05-2014, 05:02 PM   #4
Not a problem, the light doubles as a low fluid light
Old 10-05-2014, 05:51 PM   #5
Junior Member
bigred8169's Avatar
So I'm kinda new to this still trying to figure it out but my question is I currently have a pi 2valve in my car and was wanting to go to a teskid block and run my 2 valve heads and I take was wondering what my compression would b I heard rumors around 12:1
bigred8169 is offline   Reply With Quote
Old 10-06-2014, 01:40 PM   #6
thyreaper's Avatar
Prolly should start a new thread and ask so people that may know will see it and answer because no offense but you kinda hijack'd this one lol 😏
thyreaper is offline   Reply With Quote
Old 10-06-2014, 02:17 PM   #7
You should check all of your brake pads for wear. As they wear out, the brake fluid level in the master cylinder begins to drop because the pistons in the calipers become further and further extended and they require more brake fluid to fill the increased volume.
When the brake fluid level becomes low enough to trigger the warning lamp, it's usually a good indication that the pads are worn out on at least one of the axles.
Old 10-06-2014, 02:22 PM   #8
Yellastang03's Avatar
^ What stray bullitt said.
Yellastang03 is offline   Reply With Quote
Slapped from my E-brake/Parking Brake SunsetGoldGT 2005-2010 Mustang GT 2 05-28-2014 01:45 PM
Third brake light and license plate light problems bkh1994 Pre-2005 V6 Mustang 20 09-05-2013 08:34 PM
Brake noise from brake pedal blooce 2005-2010 Mustang GT 8 09-30-2012 06:41 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
08:31 AM
