Ordered Some things , Need advice - Mustang Evolution
Old 10-05-2014, 06:21 PM   #1
Slow4V's Avatar
So I just ordered
Long tube headers
Shorty Off road X Pipe
March performance 1158 fluid damper , and arp bolt.
Question ..
Should I re-use my manifold gaskets , and bolts ?
Will I feel a difference with these bolt ons ?
Was going to do nitrous but thought I would do full bolt ons first.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-05-2014, 06:27 PM   #2
You get a tune for it yet?
Old 10-05-2014, 06:35 PM   #3
Slow4V's Avatar
No actually I'm going to hold off on getting a tuber until next payday.
Old 10-05-2014, 06:59 PM   #4
The tuner should be on the top of your priority right now. Running off road exhaust without a tune isn't a good idea.
Old 10-05-2014, 08:14 PM   #5
Roguestang's Avatar
I would get new manifold gaskets, cause it's easier to put them in now, than have to later. And you can reuse your stock header studs and bolts. They've been through some heat cycles, so they shouldn't loosen much, but you can always get some grade 8 locking bolts to be sure. And get that tune next payday!
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 10-06-2014, 08:26 AM   #6
Slow4V's Avatar
Was Going To Get oem Ford Gaskets , AND Maybe Just Use Thread Locker On The Bolts Unless Someone Suggests The Lockers.
Old 10-06-2014, 08:47 AM   #7
Do not re-use manifold gaskets. If you want the best, get the Percy's Dead Soft aluminium ones. For bolts that do not back out get stage 8 locking bolts. Full exhaust with the longtubes should give you some better low end grunt on the 4V. A tune will make the biggest difference. I'd get in touch with MPT for a full blown datalog tune vs a canned one.
Old 10-06-2014, 09:06 AM   #8
Slow4V's Avatar
Cool thanks man , will do
I'll order them off late model
Just wonder if they will be a ***** to put on, because aren't the stage 8 lockers a hex head
Old 10-06-2014, 09:39 AM   #9
They're both. Allen key but also are a 6 pt head. I used them for years on my 95 and it was nice to never have to worry about a bolt backing out. And since you are dropping the K on them, use a torque wrench when you install since you will be able to get it in there. Torque to the median torque (between min and max) and then if you have to go a little tighter to get the locking arm to sit on the primary you can. Work inside to outside. Unless you are using MACs, with those stupid individual flanges.
Old 10-06-2014, 10:51 AM   #10
Yellastang03's Avatar
Grade 8 locking header bolts and ford racing gaskets. The gasket that come with the best quality headers are still garbage. I wouldn't use any type of thread locker on the bolts regardless if you go locking bolts or not. Having to heat the bolts whenever you have to take them out is the last thing you're going to want to deal with. After having to go back to retighten the header bolts after a heat cycle is a big pain so I would recommend dropping the $70 or so on locking bolts. Also a tubular k member would also be a life saver doing any type of header maintenance.
Yellastang03 is offline   Reply With Quote
Old 10-06-2014, 07:23 PM   #11
Slow4V's Avatar
Cool I'll order the stage 8 locks, and get oem Ford Gaskets to be on the safe side.
Old 10-09-2014, 11:12 PM   #12
Speed_Mister's Avatar
Region: Arkansas
I would buy a new gasket, and if the headers don't come with bolts I would buy new bolts, you also need O2 extensions!
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 10-10-2014, 08:18 PM   #13
You didn't read the thread did you?
Ordered a few things today! 11stangGT 2011-2014 Mustang GT 27 09-14-2011 07:07 PM
96 3.8l with some bolt ons whats next...? Need some advice please!!! Mavs32 Pre-2005 V6 Mustang 6 02-02-2011 04:56 PM
some things on ebay whipster24 Mustang Parts for Sale and Wanted 1 08-13-2005 07:47 PM
If you notice some weird things on the forum Its ok Brent The Bar 2 10-31-2004 08:44 AM
Need some advice on some realistic numbers from enginebasics ASSEMbler Pre-2005 V6 Mustang 25 11-14-2003 01:44 PM
12:15 PM
