1996 gt wont start - Mustang Evolution
Old 10-07-2014, 04:38 PM   #1
1996 gt wont start
I was driving and it lost all power and it died .i got it to start then the same thing again got it home and tried to start but nothing. Its sounds like the starter does not have enough power to start. It tries to but nothing happens. I replaced the starter, charged the battery and had it tested, but still nothing. When I try to start the car I can hear the starter hitting the flywheel and the lights dim on the inside of the car. I have checked all the fuses and relays and everything was fine. The alternator is new I just put it in last month. I can't find any loose wires either. All the fluids are fine and I have tested the coils, its all fine. I think it might be a P.A.T.S. problem but I do not know. i had a diagnotsic put on it a couple months ago and the only thing that showed up bad was the O2 sensor. If any one has any ideas please let me know.
2tone is offline   Reply With Quote
Old 10-07-2014, 05:51 PM   #2
Panther140's Avatar
How does your oil look? Are there pretty little sparkles in it? If your charging and starting system are all good and its definitely in neutral, then my gut tells me there are problems with the engine. Im not trying to freak you out or anything, I am not a mechanic, but my experiences with destroying every internal combustion engine that I have owned make me prone to think that.
Heres what I would do if I were you:
1- Go out and pull the drain plug from the engine right now.
2- If theres nothing abnormal, fill it back up with oil
3- If there is metal flake in it-> push it over near a big tree, buy a few hungry beavers, release them on the tree, Let them eat the trunk, let the tree fall onto and crush the car, collect the insurance money, and buy a new one.
4- In case you don't have access to beavers-> go to your local junkyard and buy a low mileage 4.6 out of a grand marquis that some granny crashed into a minivan and put it in place of your current power plant. Probably can do it under $500 in your garage. Probably under $1,000 if you know a guy who can do it..
Panther140 is offline   Reply With Quote
Old 10-07-2014, 08:43 PM   #3
johnathan2225's Avatar
Region: West Virgina
Agree with panther.. Lol
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 10-07-2014, 09:44 PM   #4
Check for a bad ground cable.
Old 10-08-2014, 06:01 PM   #5
the engine was running fine before but when i go to start it the lights dim and if i touch the brake pedal the lights dim and the chime sound acts up theres 2 plugs with 2 wires in each at the top of the pedal
Old 10-08-2014, 06:03 PM   #6
i checked all the cables down to the starter and grounds
Old 10-08-2014, 08:31 PM   #7
Alright. Try to jump start it with another vehicle. If it starts then your battery needs to be replaced
Old 10-09-2014, 03:03 PM   #8
i tried but still nothing charged the battery and tested its good the spark plugs arent getting any spark i dont have the origanal key to the car just a remake
Old 10-09-2014, 03:34 PM   #9
Still nothing huh?
The next thing to do is to test the starter and make sure that it is functional.
Old 10-09-2014, 03:38 PM   #10
Forget it. I see that you probably already replaced a perfectly good starter.
It has to be a wiring issue and I still suspect that there is a bad ground somewhere.
Old 10-09-2014, 05:20 PM   #11
mineralgt's Avatar
Take belt loose and see if motor turns over May be something like a locked up ac compressor or a pulley
mineralgt is offline   Reply With Quote
Old 10-16-2014, 04:55 PM   #12
i found the problem it was a spark plug wire that hit the fuel rail causing it to ark and burn up im gonna replace the plugs ,wires,and coils to be safe ,could it damage anything else besides what im replaceing ?
1996 mustang tempeture gage wont work? breandan 1996-2004 Mustang GT 2 12-11-2011 09:22 AM
Im repairing a 1996 mustang, and it wont start, anyone know how to re-set the ani-theft? ayawamat 1996-2004 Mustang GT 2 08-22-2009 08:07 AM
Car wont start!!! eNvy Pre-2005 V6 Mustang 5 04-29-2004 07:19 AM
help: hit a curb, car wont start. mexor The Bar 6 04-10-2004 08:18 PM
Car wont start, help: Rellik Pre-2005 V6 Mustang 28 11-30-2003 02:05 PM
08:55 AM
