help!!! - Mustang Evolution
Old 10-08-2014, 03:45 PM   #1
samcrored's Avatar
help!!!
After its warmed up when coming to a stop my car will idle down to like 200rpm and almost die. and normal idle is choppy...car shakes .....also hear a rattle when i rev it under the car but have no cel......its a 00 gt
samcrored is offline   Reply With Quote
Old 10-08-2014, 04:02 PM   #2
natestang07's Avatar
May have a vaccum leak somewhere?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 10-08-2014, 04:03 PM   #3
samcrored's Avatar
I checked earlier didnt seem to be any leaks
Old 10-08-2014, 04:06 PM   #4
My parents expidition did this and it was this little rubber elbow that was a pain in the *** to find and get to. Did you use carbon cleaner to check for leaks?
Old 10-08-2014, 04:08 PM   #5
samcrored's Avatar
Yeh carb cleaner....but like i said my exhaust rattlea...i was thinking broken / clogged cat?
Old 10-08-2014, 04:13 PM   #6
I imagine there would be a cel for that though wouldn't there?
---------- Post added at 03:13 PM ---------- Previous post was at 03:12 PM ----------
Stupid auto correct.
*carb
Old 10-08-2014, 04:14 PM   #7
samcrored's Avatar
Thats the thing...i have no cel whatso ever
Old 10-23-2014, 07:23 AM   #8
phillip433's Avatar
Idle air control valve ?
phillip433 is offline   Reply With Quote
Old 10-23-2014, 09:00 AM   #9
samcrored's Avatar
Replaced the IAC
Old 10-23-2014, 09:49 AM   #10
phillip433's Avatar
Any engine codes ?
Old 10-23-2014, 11:15 AM   #11
samcrored's Avatar
None whatsoever
Old 10-23-2014, 11:16 AM   #12
phillip433's Avatar
Do you have a tune on it?
Old 10-23-2014, 11:20 AM   #13
samcrored's Avatar
I do..however its the same without the tune
Old 10-23-2014, 11:21 AM   #14
Cbird's Avatar
Region: Iowa
help!!!
The way I check for vacuum leaks is I blow cig smoke into a vacuum line. Taking the air intake off and plugging the throttle body with a rag keeps the smoke from going that direction. If the smoke comes anywhere besides the exhaust you have a leak obviously.
The reason I say this is because I had a vacuum leak on one of those red plastic tubes coming off the plenum that didn't respond to carb cleaner. Might give that a shot.
How does your car do when you accelerate? No power loss?
Cbird is offline   Reply With Quote
Old 10-23-2014, 11:22 AM   #15
phillip433's Avatar
That's what mine was doing. you use a sct device ? I had to update mine and it fixed the problem.
I think it's the tune. If not. A basic tune up would probably fix the problem weather it's the spark plugs or ignition coils causing a misfire or something.
Old 10-23-2014, 11:24 AM   #16
phillip433's Avatar
Yeah. They sell these smoke machines where you plug it into the red wires around the intake manifold. And it shoots smoke through the whole system. Smoke coming out the cold air intake and the egr is common.
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
» Members Mustangs
Savannah
Gyro88
Red
Red89
Add your Mustang
11:31 AM
