4.6l question - Mustang Evolution
Old 10-08-2014, 04:28 PM   #1
johnathan2225's Avatar
Region: West Virgina
4.6l question
Any idea what fuel pressure is for my 4.7l?Click image for larger version
Name:	ImageUploadedByMustang Evolution1412807098.478004.jpg
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 10-08-2014, 06:17 PM   #2
thyreaper's Avatar
Should be between 40-45 under a load (when vacuum drops) if u have the return style fuel system then pull the vacuum hose off the regulator and see/set the pressure
thyreaper is offline   Reply With Quote
Old 10-08-2014, 09:04 PM   #3
Ok I'll try that.. It acts like it's not getting quite enough fuel while at idle and driving, then once I get it up in rpm and speed, it runs fast and great.. But it has stock chrome fuel rails on it, and with tune, per sct, I'm not sure if it's an issue due to fuel rails, or if it's just not getting good delivery..
Old 10-08-2014, 09:05 PM   #4
Where do I find the regulator? Any ideas? Lol
Old 10-10-2014, 03:20 PM   #5
thyreaper's Avatar
What yr is ur car? U might have a returnless system with a press sensor instead the year of ur car will answer that one for me
Old 10-10-2014, 06:50 PM   #6
I traded my jeep for it.. And was told that it started out of factory as a 94 mustang gt, 5.0l, automatic.. then a previous owner got another mustang gt, with a 4.6l, that was supposedly a 99, and swapped everything out and added some bolt ons, so I was told that it has a 94 body and rear end, with newer 99 mustang gt everything else..
Old 10-10-2014, 10:16 PM   #7
thyreaper's Avatar
Well if the fuel system is from a 99 to then u have the returnless style system and dont have a fpr u have a fuel press sensor and only 1 fuel line but if u take a pic of the fuel rail up close on the left and right sides i can tell u for sure, cuz ur situation is alil confusing
Old 10-11-2014, 10:22 AM   #8
Very confusing.. Lol. Ok I'll snap a couple pics
Old 10-11-2014, 05:43 PM   #9
Name:	ImageUploadedByMustang Evolution1413070855.222242.jpg
ID:	167742Click image for larger version
Name:	ImageUploadedByMustang Evolution1413070877.260426.jpg
ID:	167743Click image for larger version
Name:	ImageUploadedByMustang Evolution1413070916.042977.jpg
ID:	167744Click image for larger version
Name:	ImageUploadedByMustang Evolution1413070941.270284.jpg
ID:	167745Click image for larger version
Name:	ImageUploadedByMustang Evolution1413070964.015000.jpg
ID:	167746Click image for larger version
Name:	ImageUploadedByMustang Evolution1413070988.405289.jpg
Old 10-11-2014, 05:51 PM   #10
Could misfiring cause lots of back fire? Gearing down my car also sounds like it's popping pop corn.. Lol I'm still thinking that a good bit of my issues is coming from my COP's..:/
Old 10-11-2014, 10:53 PM   #11
The last picture has your FRPS in it. Fuel Rail Pressure Sensor. Looks like you have Accel COP.
Complete garbage. I'm not saying they are the problem but OEM is really the only way to go.
Are you throwing any codes? Does the MIL light blink when you are having the popping noises?
If you have an SCT tuner and a laptop you can data log and get to the bottom of it real quickly.
Popping on deceleration usually means unburned fuel or fumes in the exhaust system. Can be emissions problem, timing too far advanced, exhaust manifold leak or a host of other problems.
Check for codes first, monitor fuel pressure and start from there,
vert03 is offline   Reply With Quote
Old 10-12-2014, 09:43 AM   #12
No codes, and I've only tried once at data logging with my sct.. am I supposed to turn in data logging and just start my car, or drive it? then when I figure that out, how can I view it with my laptop? I have a program on my laptop that I downloaded from the sct site, but it's to update it, and I didn't see an option for data logging.. They say it can be tough to figure out at first, but once you do it's the easiest and quickest/best way to figure a more defined tune.. I'm probly just thinking too hard about it..
Old 10-12-2014, 01:46 PM   #13
https://support.lundracing.com/hc/en...to-Datalog-SCT
Should get you started. It's important to connect the tuner and laptop in the correct order or it won't work.
I forget what the order is
Check the SCT site for their instructions as well.
Basically create a file of what you want to log, the Lund site has a good list, save it, hook up the tuner/laptop and and then start the program using the file you created with the parameters you want to log.
Drive around and try and aggravate the symptoms. IOW make it fail.
Once you have a failure, pull over, stop the laptop, save the session and go home. Disconnect everything, open the software on the laptop and play it back until you get to the failure then look and see what's happening.
IOW:
Did fuel pressure drop when it failed?
Were you logging misfires?
Anything that looks different at the time of the failure is suspect, even if you don't know exactly what you are seeing.
Post back any results and the people here can help interpret the log.
It's really easier than it sounds.
Just resist playing with the laptop when you are driving and make sure to route the cables so you don't get your feet tangled in them.
Old 10-12-2014, 02:23 PM   #14
I ended up you tuning it, I logged misfires for all 8 cylinders twice, first run popped up a spike for cylinder 8, the second run popped up a spike for cylinder 4..
Old 10-12-2014, 03:23 PM   #15
pjtavish's Avatar
Those accel coils are crap man. I ran those coils for about 3 mins and pulled multiple misfires on all 8 cyl. Exchanged them and went with the MSD coils. Great coils!
pjtavish is offline   Reply With Quote
Old 10-12-2014, 06:23 PM   #16
Ya I just done another run, and it was misfire on cylinder 6 and cylinder 8..
Old 10-12-2014, 06:24 PM   #17
thyreaper's Avatar
Yea thats looking like its more of a random misfire if its happening on different cylinders each time, get you some Oem COP's and dont mess with the aftermarket ones and if cost is an issue try your locL salvage yard ( even tho i really dont rec used electrical like that but even those will be better then the aftermarket ones lol) but also try cleaning your MAF sensor while ur at it and run some ngk plugs or ford plugs nothing else if your still misfiring after all that then look for a intake/ vacuum leak then if all else fails check your compression but these motors usually are pretty strong in there stock/ lightly modded form so i dont usually see drop'd compression but it does happen
Old 10-12-2014, 06:28 PM   #18
4.6l question
Name:	ImageUploadedByMustang Evolution1413160012.878759.jpg
ID:	167776 so even these would be better? Scared cause of the low price, however the accels are expensive and crap, so maybe "you get what you pay for" don't apply too much in this area.. Lol
These ones might be cheap, but they have a lot of good ratings from others that have purchased them..
Old 10-12-2014, 06:31 PM   #19
Is the computer easy to get too? I'm used to one being under the hood, but can't find one there.. I'm wondering also if there's a chip plugged I to the computer, and if I'm having a battle of the chip vs sct, after reading more on sct, it states not to have any other chips or tunes while using sct..
Old 10-12-2014, 06:35 PM   #20
thyreaper's Avatar
Yea sort of the computer is inside on the lower passenger kickpanel and id go oem ford for the cop no since in wasting money on anything else
Old 10-12-2014, 06:45 PM   #21
Ok, I'll check the computer tomorrow, just in case there is a JET performance chip for example shoved in it.. Lol
Old 10-12-2014, 06:55 PM   #22
Old 10-12-2014, 07:03 PM   #23
thyreaper's Avatar
Yea i had one in mine and put in a canned tune from AM with it in there and to my suprise the sct handheld was still able to load the tune with the chip i bet my computer didnt know what to do lol
Old 10-12-2014, 07:47 PM   #24
Ya and I'm just not sure, I wasn't told very much about this mustang, the only thing the guy I got it from did to it, was put a new clutch in it.. I do know by looking at it tho that it has no cats, no rear o2's, then all the visible aftermarket on the motor.. Even PI upgrade I believe, but the COP's are a bummer..
Old 10-12-2014, 08:05 PM   #25
Name:	ImageUploadedByMustang Evolution1413165854.824579.jpg
ID:	167782Click image for larger version
Name:	ImageUploadedByMustang Evolution1413165876.614901.jpg
ID:	167783Click image for larger version
Name:	ImageUploadedByMustang Evolution1413165896.716126.jpg
Old 10-17-2014, 10:48 PM   #26
Pulled my computer today, and there's no chip in it.. So it's not that being an issue.. Lol I'm gonna clean my MAF tomorrow, see if that helps.. Lol
Old 10-18-2014, 08:25 AM   #27
Cylinder 6 and 8 are sick. Very sick
Move the COP from cylinder 6+8 to another cylinder, data log again and see if the misfires move with the COP. While you are at it check the spark plugs as well.
You can get the boot kit on Rock Auto for about the same price.
It's a high quality kit.
Also check the harness that runs along the firewall. It runs right by the EGR valve and if the tie wrap breaks it will lean against the EGR and melt the wires. I had this happen and it blew out 2 COP on my car before I figured out what was wrong.
Old 10-18-2014, 11:13 AM   #28
The run I did before the one that's pictured, said bad for cylinder 4 and 8.. Then the ones in the picture are 6 and 8.. Just confuses the **** out of me..
Old 10-18-2014, 12:22 PM   #29
Misfire caused by COP can come and go depending upon weather, load and God only knows what else.
I had two bad COP a couple of months ago (not related to the shorted cable I posted about) and while the logging did show occasional misfires on other cylinders, the two bad ones had many. many more hits.
If it were me, I would get those Accel COP out of there, make sure you running the factory tune and maybe toss some NGK or Motorcraft plugs in at the same time.
You need to set a baseline and then trouble shoot from there.
Otherwise you are going to drive yourself crazy
Old 10-18-2014, 02:58 PM   #30
WJL
From looking at the pictures you have pink injectors and orange injectors the pink ones 21 #/hr and the orange are 19 #/hr. just an observation. So if your going to the junk yard look for some injectors as well. different injector rates could cause problems
WJL is offline   Reply With Quote
Old 10-18-2014, 03:20 PM   #31
thyreaper's Avatar
He is right thats a good observation you have different injectors that could also be causing the different misfires as well as those crappy cop's. I actually think i have a set of 19/lb orange ones that ill give u just pay shipping u absolutely need them to all be of the right kind
Old 10-18-2014, 03:58 PM   #32
Lol how would I pay shipping?
Old 10-18-2014, 04:00 PM   #33
4.6l question
Today's data log.. About a regular 25-30 min drive, but done it in around 12 min.. LolClick image for larger version
Name:	ImageUploadedByMustang Evolution1413669589.614267.jpg
ID:	168057Click image for larger version
Name:	ImageUploadedByMustang Evolution1413669609.374922.jpg
Old 10-18-2014, 04:41 PM   #34
thyreaper's Avatar
Paypal?
Old 10-18-2014, 04:48 PM   #35
thyreaper's Avatar
Also count how many pink injectors u have and how many orange or yellow injectors u have u need to make them all the same ur fuel trims i bet are soo wackd that ur car dont know what to do some of ur cylinders are running pig rich and some are like they should
Question question!?!? AmericanBulldog Pre-2005 V6 Mustang 11 12-11-2013 08:24 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Question: I would like to know from you guys (See background and full question)? dumont75 General Mustang Discussion 16 03-03-2010 06:17 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
08:31 AM
