2003 GT Battery Light flickering - Mustang Evolution
Old 10-08-2014, 09:23 PM   #1
XSlashDashX's Avatar
Give it between 5 to 10 minutes the battery light will flicker on and off. Battery gauge isn't moving. Still in middle. And at night all my lights interior and exterior will dim every couple seconds. I'm assuming alternator is going out. Will get that tested tomorrow. If it is I'm looking at the SR Alternator. Any thoughts on that? Haven't seen a bad review of it.
Old 10-09-2014, 04:25 PM   #2
04beautyGT's Avatar
Just a thought, but unless you need that high of amperage for lighting or stereo, for $60 more (but 20A less) PA Performance has a painted one with lifetime warranty or go to autozone for like $5 cheaper (but 40A less) and a lifetime warranty.
Also, if the alternator checks out it could simply be a grounding problem.
04beautyGT is offline   Reply With Quote
Old 10-09-2014, 05:16 PM   #3
99_GRUMPY_GT's Avatar
My alt went out today, had to go to PEPBOYS and pick one up, lifetime warranty, and was not cheap at $240.00. I wanted to upgrade to a 150amp alt, but they did not carry any on the shelf so went OEM.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 10-09-2014, 07:08 PM   #4
My alt failed same way. Flickering battery light. It would come and go. All voltages and connections were good. Weak diode in the alt.
vert03 is offline   Reply With Quote
Old 11-01-2014, 07:30 PM   #5
Mine did the same thing, removed alternator and replaced the regulator and now everything is fine
Rocksteady is offline   Reply With Quote
battery gauge indicator bouncing/ headlight, dashlights flickering antnvlz1294 1979-1995 Mustang GT 39 03-26-2014 08:34 PM
HID lights flickering SkateMoreDvs89 2005-2010 V6 Mustang 6 11-17-2012 02:21 AM
Flickering hid Snapple750 1996-2004 Mustang GT 5 06-10-2012 01:53 AM
HID kit... They were flickering now they are stuck in hi beams any suggestions ? RedGT04 1996-2004 Mustang GT 10 10-22-2011 12:20 PM
H.I.D.'s wont stop flickering silverstang10 2011-2014 Mustang GT 4 10-15-2010 01:15 PM
11:36 AM
