Exhaust Clamps HELP - Mustang Evolution
Old 10-09-2014, 09:43 PM   #1
Slow4V's Avatar
Exhaust Clamps HELP
My long tubes didn't come with any exhaust clamps... can someone point me in the right direction to get some that will fit ?
They are 3" , and my off road X is probably 2.5"
Need help asap thanks
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-10-2014, 04:53 AM   #2
99_GRUMPY_GT's Avatar
Not knowing the brand, you have to get 2 bolt flange kits that can be welded on. It looks as if your header collector has a flare to them at the end, that is to me a problem as the flange ring inside OD should be smaller than that flare at the end and the flange ring would just be a slider, and would not be welded. Is the collector itself 3" before the flare or are you measuring at the flare to get 3"? The X you have is a system called ball and socket. The X is the ball portion and the header is the socket. Combined they form a seal based on a ball and socket method. What I would do is get a collector flange kit and have it welded onto the header collector.Welding it would help ensure it to hold up to vibration and cracking. But then again it is the quality of the welder that would ensure the resistance to crack from bottoming out and vibration.
The kits should be available at any auto parts store.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 10-10-2014, 06:55 AM   #3
Slow4V's Avatar
My headers are a slip fit style it slips over the x pipe
I think I'll find universal ones
Old 10-10-2014, 07:31 AM   #4
The slip fit will not work unless the header flange is bellowed to accept the ball of the X-pipe. If the header collector is completely round with no bellow you can not mate the 2, based on the pics you provided. You would have to get a bellowed flange kit to acept the X-Pipe. Only other way around that is to cut the ball portion of the X-Pipe off to slide it into the collector portion.
Old 10-10-2014, 10:42 AM   #5
Slow4V's Avatar
Well I've seen plenty of guys use a clamp for their slip fit so that's what I'll do.
Thanks anyways
I already know what to buy .
Old 10-10-2014, 10:43 AM   #6
Slow4V's Avatar
Going to do this.
If you can see the clamp
Old 10-10-2014, 02:15 PM   #7
In your pics in the other thread, you have so many going on at once, the X-Pipe is backwards and shows the socket side at the headers. So yes you can slide them on and clamp it. I do not know why you have 10 different threads going on at the same time for the same relative thing.
Anyway, hope it works out well for you.
Old 10-10-2014, 02:23 PM   #8
Rapinator126's Avatar
Going to do this.
Don't use that they don't seal good.
Here are the ones I use. No leaks works perfectly.
http://www.latemodelrestoration.com/...ust-Clamp-Pair
Old 10-10-2014, 02:52 PM   #9
Slow4V's Avatar
Will they fit that 3" to 2.5" ??
---------- Post added at 03:52 PM ---------- Previous post was at 03:51 PM ----------
It's called yolo
Old 10-10-2014, 06:20 PM   #10
It's called yolo
It may
Good thing is if you buy one that is slightly to big as you tighten it will form to the pipe, and fit like a glove
Old 10-10-2014, 08:32 PM   #11
The link provided to you by rapinator is a good one, the clamps are also known as band clamps. They have a bead of tar on each side to form a tight seal on both ends. The band clamps come in a wide varity of sizes, and they are sized like what you want, 3" on one side and 2.5 on the other. But I would buy them from Summit Racing than LMR.
Pypes Mustang 3" Exhaust Clamp, Pair Stainless
exhaust
Borla exhaust clamps Awest31 2011-2014 V6 Mustang 8 03-22-2014 01:02 AM
Exhaust clamps XSlashDashX 1996-2004 Mustang GT 3 02-15-2014 11:28 AM
c clamps Venemous02GT 1996-2004 Mustang GT 8 05-11-2012 08:45 AM
bell clamps Supertzi 2011-2014 Mustang GT 5 01-09-2012 09:31 AM
CAI Clamps Foxone Pre-2005 V6 Mustang 5 07-07-2009 07:59 AM
12:50 AM
