Launching and traction advice? - Mustang Evolution
Old 10-13-2014, 05:30 PM   #1
Hey guys, I'm about to get a tune from MPT in the mail pretty soon, but I realized I have, and will have worse with added torque, a problem with traction. I'm in a bad need of mods to improve my traction off the line at the drag, as I can't launch above 1,000 rpms without burning out through first and second gear. I already have wide Nitto NTO5s on the rear, so that's checked off. I'm already looking at better control arms to help launch. What else is there to do?
Thanks in advance.
CameronChapman is offline   Reply With Quote
Old 10-13-2014, 06:07 PM   #2
V6 stang's Avatar
Thanks in advance.
Steeda lca's
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 10-13-2014, 06:11 PM   #3
Rapinator126's Avatar
Loose the tires, nitto does not make a good street tire. Only tire they make worth a crap is the NT05Rs ( the drag radial )
Then Lca's and UCA.
Old 10-13-2014, 06:12 PM   #4
Slow4V's Avatar
Full length subframe connectors , welded in
Lower rear control arms
Upper rear control arms
adjustable rear shocks
Good drag springs
Take off front sway bar
90/10 struts
Good set of drag radials set them at 18 psi
Driver mod
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-13-2014, 07:44 PM   #5
Just how much of a difference do control arms make?
Old 10-15-2014, 07:52 AM   #6
Slow4V's Avatar
Day and night
Old 10-16-2014, 08:17 AM   #7
Originally Posted by Slow4V View Post
Day and night
Dang... I need to get the money for some now.
Old 10-16-2014, 06:56 PM   #8
What else could I do to add power? I recently got a MPT tune that jacked my power up, but I still want to add power that's not NOS or Forced Induction. Any ideas?
Old 10-16-2014, 10:24 PM   #9
Steve96's Avatar
What bolt ons do you currently have? Can do the infamous CAI (which is debatable if it really increase power on certain mustang's), UDP (there is a couple threads on here about them, some currently ), exhaust and mid pipe or a cat back set up, throttle body and Plenum, etc.
1996 GT
Old 10-16-2014, 11:52 PM   #10
Then Lca's and UCA.
The NT05 is pretty good. But thats more geared toward cornering than putting raw power down.
Old 10-17-2014, 06:58 AM   #11
I really wish the guy at Discount Tire would've told me that... I also just found out that I have 4.10 gears, that THAT explains why I spin my tires at every launch.
Old 10-17-2014, 01:10 PM   #12
thyreaper's Avatar
I thought lca's and uca's ull start ripping out ur torque boxes and even more so adding slicks to the equation
thyreaper is offline   Reply With Quote
Old 10-27-2014, 11:20 AM   #13
LCAs won't affect the torque boxes, UCAs can, that's why you will want to reinforce the torque boxes when you put them on.
Old 11-13-2014, 01:53 AM   #14
Speed_Mister's Avatar
Region: Arkansas
When launching you can't go WOT the second you disengage your clutch or you will spin off the tires. If your at full bolt on N/A car then it's pretty easy, after you disengage (pop) your clutch at around 2750rpms, give it JUST ENOUGH throttle so it won't bog ease into the throttle for about half a second then you should be at WOT and that's it. If your at around 330-400rwhp you may have to play with the throttle a lot more, and depending on tires, surface prep, and etc.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
What kind of suspension do i need for drag racing and launching in straight lines Speed_Mister 1996-2004 Mustang GT 1 03-04-2013 08:52 PM
Chevrolet is planning on launching special edition Camaro models, such as the ZL1, ev Brent General Car Discussion 23 02-16-2011 07:21 PM
optimal launching RPM stangaroo Pre-2005 V6 Mustang 1 04-05-2009 08:22 PM
Assistance with N2O and launching DarkShadow 1996-2004 Mustang GT 20 04-20-2007 09:51 PM
Launching RPM ttpancakes Pre-2005 V6 Mustang 37 07-27-2004 12:11 AM
12:54 AM
