T56 swap quick question - Mustang Evolution
Old 10-17-2014, 07:45 AM   #1
phillip433's Avatar
Okay so I have the whole setup for my 03 gt
Driveshaft, tranny, and crossmember.
Do I need anything else. I know I need clutch and shifter. What about the harness. I researched that I
Can just modify my own harness from previous tranny. Or instead just forget the tranny and replace the spring for reverse. Also Do I need the flywheel from a cobra? Anything y'all would like to
Add on would be great. Thanks guys
phillip433 is offline   Reply With Quote
Old 10-17-2014, 11:40 AM   #2
Unless you have a Terminator engine, that transmission is going to SUCK *** behind your 2V engine...
Old 10-17-2014, 11:41 AM   #3
phillip433's Avatar
Damn. Not something I want to hear. How come ?
Old 10-17-2014, 11:46 AM   #4
thyreaper's Avatar
Why? I mean 6th gear will take sum power to pull up a hill but no one puts a t56 in there and leaves the motor stock for long and untill u can just run 5th untill u are making more power or up to speed and on flat surface
thyreaper is offline   Reply With Quote
Old 10-17-2014, 11:48 AM   #5
Because first gear is a lot taller in the T56. You need to be at Terminator power levels to make it work.
I know a guy that bought a "bolt-on" GT with one already installed and his very first mod was to remove it and install a 3650.
Old 10-17-2014, 11:52 AM   #6
phillip433's Avatar
Well it seems like no one really has first hand experience. My car has full bolt ons and it's cammed out and headers and blah blah blah. My synchros went out in my 3650, so I just assume upgrade now cus eventually I will boost my gt.
Old 10-17-2014, 11:53 AM   #7
thyreaper's Avatar
Dam that sux I've always wanted to go to the t56 but when i do ill have 370+ whp cuz of the blower im about to put on my car
Old 10-17-2014, 12:02 PM   #8
Once you guys supercharge, that will be a nice transmission!
Until then... Not so much.
Old 10-17-2014, 12:15 PM   #9
6th gear won't be an issue, if it's the one from the cobra then it'll be .62 which is the same as the 02+ TR3650's 5th gear. It's the 2.66 1st gear that is going to bog the hell out of the car unless it has the power low enough to get you out of it. (I.e. Twin screw)
Old 10-17-2014, 12:15 PM   #10
phillip433's Avatar
I drove a stock gt with a t56. And it's not bad at all. Felt like i had plenty of power left through out the gears. No need for 6 unless you are on the highway. But that's what influenced me to get it. Imma do it anyway just cus I experienced how it drives.
Old 10-17-2014, 12:17 PM   #11
phillip433's Avatar
On that note. I did feel little bogging compared to 3650 1st gear. But it's not that serious.
Old 10-17-2014, 12:22 PM   #12
There is another T56 that is actually a better choice for us. It's the 2.97 1st gear one, not as much bog and the overdrive is a .5 which really makes the rpms low on the highway. This is the one that came in GM cars like the Camaro and Corvette.
Old 10-17-2014, 12:24 PM   #13
phillip433's Avatar
Yeah. But I researched that those can't mount up with ford engines.
Old 10-17-2014, 12:26 PM   #14
thyreaper's Avatar
But can u use a t56 that came in a trans am ws6 or the vette and change the bellhousing? I was under the impression that you couldnt because i was looking to do that because the gm t56s are cheaper then to try and find a terminator t56 trans
Old 10-17-2014, 12:28 PM   #15
No, but you can get a T56 Magnum with the 26 spline input shaft rated past 700 pounds of torque for like $2800.
That's the route I'm going BTW.
Old 10-17-2014, 12:50 PM   #16
And to answer your original question, yes, your flywheel will work.
Old 10-17-2014, 12:50 PM   #17
phillip433's Avatar
^ thank you. I just need to get a cobra clutch and a shifter then.
Old 10-17-2014, 12:52 PM   #18
phillip433's Avatar
The cobras came with the 10 spline correct ?
Old 10-17-2014, 12:52 PM   #19
Ish416's Avatar
You won't be able to use the trans out of any Vette. They are rear mounted in those cars. F-body/Cobra/Viper trans are likely the most common sources of the T56.
Also, the vast majority of the T56 are the 2.66 first and .5 sixth. Which, with 4.10's should be fine. That should be around 40 MPH @ 6,000 rpm in first with factory size tires. Which I think is the same as what the car does stock on factory gearing.
The 2.97 first gear was originally used in the C5 Z06, not sure what other cars have it.
You could also look into a TR6060. They are basically in everything from the last 7 years that has a Tremec 6 spd. I believe these also have the same housing as the T56, but I think the shifter location may be different.
Old 10-17-2014, 12:56 PM   #20
I believe the splines are different but that is something you'll have to Google.
Old 10-17-2014, 01:04 PM   #21
thyreaper's Avatar
"F-body/Cobra/Viper trans are likely the most common sources of the T56"
So could i use one out of these cars and swap bellhousings? And i think the older vettes that used the 6 speed theres one vette that had it mounted behind the motor i believe it was a c4? The ones that first started using the 6 spd
Old 10-17-2014, 01:21 PM   #22
Ish416's Avatar
To my knowledge, all corvettes have rear mounted transmissions.
I'm not sure if just swapping the bell housing is all that's needed or if the shifters are located in different spots. I know that there are a few variations of the TR6060 that have the shifter located in slightly different locations and shifter relocation kits are available.
I'm just not sure if the Fbody/Cobra/Viper shifters are located in the same spot or not.
Old 10-17-2014, 01:43 PM   #23
I know that the 03 Corvette 50th anniversary has it. Cause that's what's in my parents corvette.
Old 10-17-2014, 09:42 PM   #24
thyreaper's Avatar
I remember working on a older 6speed vette ( im talking older then the 2000's ) that had a reg trans and irs cuz i remember asking myself if it would work in my car i been up under it so i know it was not in the rear it was a legit 6spd trans but of course with a chevy bellhousing i wanna say it was a late 80s early 90's model (c4 corvette with the zf 6 speed trans)
Old 10-17-2014, 09:57 PM   #25
Ish416's Avatar
You are correct, it's the C5+ (1997+) that have the rear mounted transmissions.
I could have swore that a friend had a mid 90's C4 (LT1) that had a rear mounted trans.. perhaps I did more drinking than wrenching that night.
Old 10-17-2014, 10:51 PM   #26
thyreaper's Avatar
Lol, but i wonder if they make a adapter or a bellhousing to mate it up with the modular motor
Old 10-23-2014, 07:41 AM   #27
phillip433's Avatar
I currently have the spec stage 2 clutch and do need to change it, should I go with the used cobra clutch or should I get a new clutch disk for the spec
Another t56 swap question jmoon4 Pre-2005 V6 Mustang 0 02-25-2014 02:33 AM
T56 Swap question jmoon4 Pre-2005 V6 Mustang 0 02-23-2014 01:36 AM
TR 3650 to T56 swap Cobraman8801 1996-2004 Mustang GT 0 06-15-2012 07:19 PM
02 mustang gt>forged cobra swap,t56, $10,000 SimplyOrange Mustangs for Sale and Wanted 44 10-08-2008 03:19 PM
T56 SWAP madmax680 1979-1995 Mustang GT 13 05-04-2007 12:33 AM
04:28 AM
