Help with pilot bearing removal - Mustang Evolution
Old 10-17-2014, 10:08 AM   #1
cstyle408's Avatar
Ive tried the slide hammer with puller. Ive tried the bread trick. And ive tried the wet paper trick. Is there a certain technique or something to get the pilot bearing out? Its in my 98 gt. Motor is still in the car. Transmission has been removed.. Any & all help is always much appreciated. Thank you
cstyle408 is offline   Reply With Quote
Old 10-17-2014, 10:35 AM   #2
Have you tried the grease trick?
I've had to chisel them out, in the past.
Old 10-17-2014, 10:37 AM   #3
thyreaper's Avatar
I had to take a small die grinder with a smaller cut of wheel and cut it then hammer/chisel it out none of the "tricks" ever seem to work for me either if you dont have a high end puller then ur pretty much screwed unless u get lucky or cut it like i did but thats risky because thats ur crank so you gotta be super careful
thyreaper is offline   Reply With Quote
Old 10-17-2014, 11:32 AM   #4
cstyle408's Avatar
Yea i tried the grease trick. I think im gonna try the chisel way. I already broke one of the fingers off of the slide hammer puller
Old 10-17-2014, 11:36 AM   #5
cstyle408's Avatar
How did u chisel it out? And with what?
Old 10-17-2014, 11:56 AM   #6
thyreaper's Avatar
What i did was took my cutting wheel and cut the center part of the bearing out then the outer race part was left i cut that being careful not to hit the crank (slow and steady does it) just cut a slot on one or each side then take a chisel and hammer and chisle it in pretty much collapsing it in on itself then just took pliers and pulled it out , i slightly nick'd the crank but it didnt do any damage to it and if u slip with the chisle just take a small file and clean it up to where it's smooth and thats it no more then what's necessary ( i didnt have to when i did mine but thats what i woulda done)
Pilot bearing 99redgt 1996-2004 Mustang GT 1 04-01-2012 08:03 PM
Pilot Bearing? 19ClearCobra96 1996-2004 Mustang GT 3 04-28-2005 08:16 AM
03:22 AM
