Abs and traction control light - Mustang Evolution
Old 10-17-2014, 05:30 PM   #1
Yellastang03's Avatar
Lately my traction control light and abs light will kick on for about 5 seconds and then go away about every 10 miles or so for no reason with no true spin what so ever. Under completely normal driving conditions. Anyone ever heard or experienced this? 2003 gt.
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
With no tire spin*
Yellastang03 is offline   Reply With Quote
Old 10-17-2014, 06:20 PM   #2
Do you mean that both the ABS and the "tire spinning" icon light up at the same time?
Do you have a staggered wheel setup on your car?
Old 10-17-2014, 07:14 PM   #3
2stang's Avatar
could be as simple as wheel sensors getting brake dust buildup and need cleaning, or control unit could be malfunctioning, check and clean abs sensors and connections, also may want to clean control unit connection, intermittent problems can be a pain to track down,
2stang is offline   Reply With Quote
Old 10-17-2014, 07:24 PM   #4
I mean both the abs light and the loss of traction light. And also have the stock square set up. Yeah I'll run through all the abs sensors to see how they look. Just thought it was really odd.
Old 10-17-2014, 07:40 PM   #5
It is odd!
Mine went berserk like that right before it stopped working completely.
The "spinning tire" would stay lit up with the car at a dead stop.
Old 10-18-2014, 08:33 AM   #6
Like 2stang says, dirt on the sensors. They pick up metallic particles and get a metallic "fuzz" on them which screws up the signal pulses back to the computer. Clean them and also check for frayed wires around the sensor or connector.
vert03 is offline   Reply With Quote
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
ABS light on and Traction Control off Constantine 1996-2004 Mustang GT 16 11-14-2013 05:43 AM
ABS & Traction Control light ON!!! Stryker01 2005-2010 V6 Mustang 3 02-22-2013 08:31 PM
Different Tire Size and Traction Control/ ABS Issues TimeMachine 2011-2014 Mustang GT 17 07-04-2012 11:08 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
08:22 PM
