Header Gaskets / What causes blown gaskets - Mustang Evolution
Old 10-23-2014, 09:06 PM   #1
Slow4V's Avatar
Okay so my long tubes came with gaskets that are kinda look like rubbery or flexible ..
My dad says they will work fine.
I did buy stage 8 locking bolts for My install , should I go ahead and install the header gaskets that came with them?
What causes a header gasket to blow ? Is it the bolts backing out ?
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-23-2014, 09:13 PM   #2
Joaquin_ii's Avatar
I used the gaskets that came with my headers and they are holding up fine. I've never blown a header gasket and they have always been like that.
If you are sketchy about it you can re use your old gaskets and they will hold up fine.
Joaquin_ii is offline   Reply With Quote
Old 10-23-2014, 09:21 PM   #3
Slow4V's Avatar
How long they been on there ?
Old 10-23-2014, 09:22 PM   #4
Joaquin_ii's Avatar
On this car about 4 months. Previous car about 6 years
Old 10-23-2014, 09:23 PM   #5
Joaquin_ii's Avatar
Or you can find some all metal gaskets shouldn't break the bank honestly
Old 10-23-2014, 09:26 PM   #6
Slow4V's Avatar
Ford wanted 120 for the gaskets lol I said nooooo
Old 10-23-2014, 09:28 PM   #7
Joaquin_ii's Avatar
Haha I would have the same thing!
Have you checked aftermarket?
Old 10-23-2014, 09:30 PM   #8
Slow4V's Avatar
Yeah but wanted something quick , I want to install them Saturday or Sunday ..
But iffy about gaskets.
Old 10-23-2014, 09:34 PM   #9
Joaquin_ii's Avatar
Yea you can't go wrong with the gaskets. Search the forum for your brand and gaskets chances are if anyone has had problems they would have posted it. Good luck!
Old 10-23-2014, 09:38 PM   #10
I would either find quality metal gaskets (check hardware stores) or reuse the factory ones. I've done 5-6 sets of headers and have always reused the OEM metal ones instead of the cheap paper/ rubber ones that they provide with the headers and had zero issues.
StarzTA17 is offline   Reply With Quote
Old 10-23-2014, 09:58 PM   #11
Slow4V's Avatar
Just check to see if they are cracked ? Or obvious signs ?
Old 10-24-2014, 12:39 AM   #12
Use Percy's header gasket
Judge_dredd is offline   Reply With Quote
Old 10-24-2014, 06:23 AM   #13
mystang50's Avatar
When I did my headers (bbk) they blew out in a few months, then I went threw another set. but at auto zone, they had some soft flexible aluminum ones that have been on there for over a year now and work great. They were thick and multiple layered. I recommend looking into them.
Old 10-24-2014, 11:17 AM   #14
Lorraine's driver
ab_mach1's Avatar
Leaky headers sucks pretty bad though. You don't get good exhaust readings on your O2 sensors. It might be best to use some quality ones. $120 sucks tho! The locking bolts may help a lot cause that's what you see most - bolts backing out because of the heat expansion and contraction.
2004 Azure Blue Mach 1
IG: @azurebluemach
Instagram: @ab_mach1
Old 10-24-2014, 11:52 AM   #15
phillip433's Avatar
After reading this. It kind of worries me if I have a leak somewheres near the headers.😳😳
phillip433 is offline   Reply With Quote
two problems..believe one causes the other. eddie1 1996-2004 Mustang GT 33 07-29-2015 02:20 AM
rpm causes speedo jump Dgerow12 Pre-2005 V6 Mustang 1 08-29-2012 08:13 AM
2007 V6 Mustang noise at 90mph????? causes? espowyes15 2005-2010 V6 Mustang 4 04-04-2010 01:28 AM
Deep Impact causes lawsuit over messed up Horoscope Brent The Bar 13 07-08-2005 08:02 AM
local mustang club causes ricer arrest tire The Bar 3 01-31-2004 07:48 AM
07:05 AM
