Ok, something is not right - Mustang Evolution
Old 10-24-2014, 06:23 AM   #1
samcrored's Avatar
00 mustang gt...k...it started idling very low and almost dying when coming to a stop. (on stock tune)...so i loaded a sct tune..did the same. ok. i replaced the IAC twice. no vacuum leaks, cops are good o2 are good, MAF is good literally everything checks out on the computer. but it still has that low dropping idle. Also....after the second IAC it idled bad on tune...idles right on stock tune. i am so confused. before it was the stock tune that started messing up. now the stock tune is working fine but any of the act bama tunes are idling low. note: i have had bama tunes on and off the car for a year, it NEVER did this before. so....can it be the tune? why would the tune change randomly? im so over this crap
samcrored is offline   Reply With Quote
Old 10-24-2014, 07:16 AM   #2
Cbird's Avatar
Region: Iowa
If you frequently switch tunes out a lot there is always the risk that they have corrupted. That's literally the only thing I can think of. This mustang is really giving you a headache isn't it? :p
I've had a tune corrupt before and what I was instructed to do was: return car to stock and unhook the battery,install the latest drivers for my x3, get copies of my tunes from Bama and re-upload them to my x3, re hook battery and throw the tunes back ok.
Might want to start there.. Hang in there bro
Cbird is offline   Reply With Quote
Old 10-24-2014, 07:23 AM   #3
samcrored's Avatar
I actually did that once before but for a different reason...but yeah i am getting tired of it .. i hate driving it with the stock tune but it doesnt want to die on me lol...
Old 10-24-2014, 11:13 AM   #4
Lorraine's driver
ab_mach1's Avatar
Maybe the throttle position sensor is bad or going bad..?
2004 Azure Blue Mach 1
IG: @azurebluemach
Instagram: @ab_mach1
Old 10-24-2014, 11:17 AM   #5
samcrored's Avatar
would it be the tps ...if it runs normal with no tune now? and bad with the tune?
Old 10-24-2014, 11:21 AM   #6
Lorraine's driver
ab_mach1's Avatar
No, probably not. I think you said it had the problem with both stock and the new tune. It just wasn't as bad right?
IG: @azurebluemach
Old 10-24-2014, 12:10 PM   #7
Lorraine's driver
ab_mach1's Avatar
And if it only happens with an aftermarket tune, you might try rotating the MAF sensor housing about 1/4 turn. Sometimes the aftermarket CAI and fancy filters can change the airflow direction slightly so it's not flowing over the sensor as well. Some peeps have this issue when they remove the MAF screen and some don't. As always, make sure you don't have any leaks in you intake tubing. Unmetered air will always cause funky probs.
IG: @azurebluemach
Old 10-24-2014, 12:24 PM   #8
Laquisha's Avatar
Same thing happens to me at idle too' Drop to like 200 bounces up to 1000 then 500 then 750 then 500 etc. This happened recently, but before my car was tuned.... HMMM?
Old 10-24-2014, 05:31 PM   #9
Cbird's Avatar
Region: Iowa
In your case it's probably the idle air control valve
Help brand new car something isnt right Aruiz42 General Mustang Discussion 10 12-27-2012 02:17 PM
Something isn't right here...... Brent Pictures and Videos 1 05-21-2008 01:22 AM
Made Some Changes.... let me know if something doesnt work right Brent ME Site Help & Announcements 3 02-23-2007 06:10 AM
Bout Time Bush Does Something right bluemustang The Bar 26 10-06-2006 10:08 PM
right place at the right time with a camera (2 owned pics) fast64 The Bar 8 05-12-2004 10:20 PM
04:50 PM
