97 mustang gt hot - Mustang Evolution
Old 10-25-2014, 04:52 PM   #1
97 mustang gt hot
My 1997 mustang gt ran hot. there was oil in the water. i have changed the crank shaft, spark plugs, and filter. i drained all the water out the radiator and oil. it cranked one time but it won't crank again. what should i do? thanks.
caulderk is offline   Reply With Quote
Old 10-25-2014, 05:52 PM   #2
Steve96's Avatar
Head gasket issue possibly? I know you don't want yo hear that of course.
1996 GT
Old 10-25-2014, 05:53 PM   #3
Steve96's Avatar
Any smoke?
1996 GT
Old 10-25-2014, 06:29 PM   #4
Omg
---------- Post added at 06:29 PM ---------- Previous post was at 06:28 PM ----------
No. No smoke
Old 10-25-2014, 07:22 PM   #5
is no smoke good or bad?
Old 10-25-2014, 07:59 PM   #6
Steve96's Avatar
There can be white colored smoke with a kind of Sweet smell from the coolant. It's a sign of a bad head gasket. How hot did the car get? Were you able to shut it down as soon as it heated up?
1996 GT
Old 10-25-2014, 08:01 PM   #7
Steve96's Avatar
Did the oil have any whitish froth? Almost like a little bit of a film when you checked it?
1996 GT
Old 10-25-2014, 08:08 PM   #8
there was gunky looking stuff in the radiator. it was a grey color. the oil was thin. when i drained the oil it had water in it but it was not white.
Old 10-25-2014, 08:39 PM   #9
Steve96's Avatar
Any coolant leaking? Like under the intake manifold? Or have you been having to add coolant/water at all?
---------- Post added at 09:39 PM ---------- Previous post was at 09:39 PM ----------
The radiator could be gunked up from just needing to be flushed.
1996 GT
Old 10-25-2014, 08:42 PM   #10
Steve96's Avatar
Could do a pressure test to see? Also if the motor overheated there could be different issues like warped or cracked cylinders? That would cause it not to want to start. I'm sure others will chime in with some helpful info Also.
1996 GT
Old 10-25-2014, 09:00 PM   #11
Steve96's Avatar
Can do a block test. Basically is like a big dropper and you insert it into the radiator fill hole and inject a blue solution, if it turns a certain color, I believe yellow then It's most likely a blown head gasket. I think you can buy them at autoparts stores.
1996 GT
Old 10-26-2014, 02:19 AM   #12
i did drain the radiator.
Old 10-26-2014, 12:31 PM   #13
Blown head gasket.
Old 10-26-2014, 01:43 PM   #14
Cbird's Avatar
Region: Iowa
97 mustang gt hot
After sitting overnight is the car hard to start in the morning? After driving the car on a normal trip take the oil cap off and see if there is a milky ring around the cap. Should be yellowish in color.
Running hot, water in oil, and oil in water are the tell-tale signs of a blown head gasket.
I've always had luck with a product called blue devil head gasket sealer. Put 70k miles on a car with this stuff and it's still driving fine to this day. If nothing else you can use this product to buy yourself some time to...ya know... Get rid of the car ...
Cbird is offline   Reply With Quote
Old 10-26-2014, 01:46 PM   #15
CBIRD, it won't crank. I drained all the water because there was gunky stuff in the radiator. It still won't crank.
Old 10-26-2014, 05:47 PM   #16
Cbird's Avatar
Region: Iowa
Like it doesn't even try to turn over now?
Old 10-26-2014, 10:42 PM   #17
Steve96's Avatar
From the sounds of this, it could be bad if it won't turn over now. If that is the case it must have got pretty hot when it overheated. No signs of coolant loss before this?
---------- Post added at 11:42 PM ---------- Previous post was at 11:41 PM ----------
I would Maybe take it to a reliable Shop and have them take a look to see if they can give you some info.
1996 GT
Old 10-27-2014, 08:45 AM   #18
Ok. Thanks
Old 10-27-2014, 10:51 AM   #19
thyreaper's Avatar
If it wont crank at all are u sure u even got power? It might be a coincidence that u lost power when all this happened or u unhooked something when u worked on the car, now if when u try to crank it and it makes a "clunk" kind of sound the motor could be locked up but if not i would retrace my steps and see if u forgot to hook something up or the battery connection got loose
thyreaper is offline   Reply With Quote
Old 10-27-2014, 11:33 AM   #20
I am checking the starter now. I've already replaced the battery
Old 10-27-2014, 05:16 PM   #21
thyreaper's Avatar
Well when u hit the key what is it doing? Like is it making a noise ? Put a socket on the crank pulley bolt and see if u can turn the motor over by hand if it moves make sure it will spin atleast 2 full revolutions if it does then u have a starter/power issue, if it wont then take a 1/2 ratchet and release the tensioner/belt and try again if it still wont then ur motor is locked up (which for me id use that as a excuse to put me in a pi motor)
Old 10-27-2014, 05:20 PM   #22
It does turn over. I just replaced the starter but it still won't start. Yesterday I got it stared and water was dripping from the tail pipe. After I turned it off it would not start again.
Old 10-27-2014, 05:21 PM   #23
thyreaper's Avatar
97 mustang gt hot
Ok so when u hit the key it turns the motor over and just doesnt start?
Alittle water out of the tailpipe is normal can be condensation now alot of white smoke that doesnt go away is very bad
Old 10-27-2014, 05:24 PM   #24
No. It won't start. It sounds weak
Old 10-27-2014, 05:26 PM   #25
There's no white smoke.
Old 10-27-2014, 05:59 PM   #26
thyreaper's Avatar
There wont be no smoke if it wont run , if the starter is turning the motor over decently and it isnt starting and sounds weak then id be willing to bet that u blew a head gasket or warped a head or both, in any case id still get a jy pi motor and throw in there and call it a day that away u came out on top anyway, here i bought my jy motor for $100 it came complete from intake to oil pan and i paid another 100 for them to pull it because it was soo hot outside that it was worth it to me to not stand out there pulling it lol
Old 10-27-2014, 06:05 PM   #27
Ok. I'll try that. Yesterday it ran for over an hour and there was water and smoke coming out but then it stopped. When I turned it off it would not come back on again.
Old 10-27-2014, 11:26 PM   #28
Steve96's Avatar
Sounds more and more like a blown head gasket with some internal damage as well to me. I know That's not what anyone wants but if it is take this opportunity to get the PI motor. You can find them everywhere as they were used in several model Ford cars. How many miles does your motor have currently? Just curious.
1996 GT
Old 10-28-2014, 03:51 AM   #29
It has over 232,000
Hot Lap: Mustang Drifting, Ridiculous Burnout & 2015 Mustang Parts - AmericanMuscle AMAlexLazarus AmericanMuscle 1 10-02-2014 09:55 AM
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
Hot Mustang Girls... Need Help Choosing AMNick Pictures and Videos 23 07-25-2009 11:06 PM
04:50 AM
