gas tank - Mustang Evolution
Old 10-26-2014, 06:53 AM   #1
gas tank
When I go to the gas station I cant seem to fuel my car. Its as if the filler neck is clogged or something, If I just barely put the tip of the nozzle in I can get the gas to go in but it will still click off every few seconds. Is there anything I can do to fix this without dropping the tank? any easy fixes? is this common?
Hello is offline   Reply With Quote
Old 10-26-2014, 08:16 AM   #2
The_Chech's Avatar
Are you only going to one gas station or multiple? I've had this happen a few times. What can cause this is the pump for the gas is to strong causing the fuel that is entering the hole to sorta bounce all over the place and trip the sensor to stop the pumping. One thing you can try is to pump at a slower rate then full. About 3/4 of the full blast. I've found a gas station that wouldn't let me full the car unless it was at like half speed before and it took forever....
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 10-26-2014, 09:31 AM   #3
no multiple. and yes I have to barely pull the trigger and just barely have the tip of the nozzle in and even then it will click off or come back out as if im over filling it. takes forever just to put 20 dollars in. Its like a clogged sink hah
Old 10-27-2014, 06:04 PM   #4
thyreaper's Avatar
Ive never heard of a filler neck clogging like that unless some kid or sum1 sabatoged it and shoved something down there and in that case pulling the tank and ramming a rod or something down thru it is the only option unless u can see something in there with a flash light and try using a coat hanger or something to pull it out, try to look down it with a light
thyreaper is offline   Reply With Quote
Old 10-28-2014, 11:18 AM   #5
Getn off's Avatar
There is a vent check valve that may have gone bad. Not ssure if it is an integral part of the tank on ur car, or if u can replace the valve itself. Hunt down a fuel schematic and find out.
Good luck.
Troy
Getn off is offline   Reply With Quote
Gas smell after full tank of gas 93mstnglx 2.3 Mustang 15 02-11-2013 09:37 PM
Big Problem with the gas tank/filler neck/fuel etc runvsofthisbull Pre-2005 V6 Mustang 4 08-16-2010 08:30 PM
Possibly Fuel Leak, Gas Tank Mustang1804 1996-2004 Mustang GT 33 04-03-2010 09:46 PM
1996 GT Leaky gas tank? BILLFORD01 1996-2004 Mustang GT 4 08-13-2009 07:59 AM
O no, Gas Tank Leakage Kiljosh Pre-2005 V6 Mustang 9 10-29-2004 08:22 PM
02:45 AM
