Exhaust gasket - Mustang Evolution
Old 10-27-2014, 02:45 PM   #1
XxFLoridaboYxX's Avatar
Exhaust gasket
I have a leak at my header/manifold gasket and everyone is telling me I have to drop the k member to change a 15$ gasket is there any other way it's on the driver side and a shop quoted me 459$ to do the job lol
XxFLoridaboYxX is offline   Reply With Quote
Old 10-27-2014, 05:46 PM   #2
Cbird's Avatar
Region: Iowa
I know I had to drop the k member to do my longtube install on my 01.
It might be do-able by someone with really small hands (like that guy from the Burger King commercials) but a normal "good ol boy" mechanic will probably struggle getting clearance.
Cbird is offline   Reply With Quote
Old 10-27-2014, 05:47 PM   #3
Looks like I have to find someone with small hands lol
Old 10-27-2014, 07:52 PM   #4
Slow4V's Avatar
Have to drop k member
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-27-2014, 07:53 PM   #5
There is no other way ? And I don't have a lift how hard is it to drop a k member in the garage
Old 10-27-2014, 08:26 PM   #6
Old 10-27-2014, 08:45 PM   #7
fwalck's Avatar
If you have stock manifolds you dnt have to drop the k member I replaced the gaskets on the passenger side of my Mach I had to remove the starter and it was a pain in the button but I got it done.
fwalck is offline   Reply With Quote
Old 10-27-2014, 11:00 PM   #8
Slow4V's Avatar
I just dropped mine , just need a couple Jacks and someone to help. Maybe you can get it with it on , but tight space.
Old 10-28-2014, 11:58 AM   #9
fwalck's Avatar
Space was very tight but getting the starter off was the worst part of it
Old 10-29-2014, 02:34 PM   #10
Billgluckman's Avatar
I did it on the passenger side if I remember correctly. It's no fun but doable.
You're gonna have to loosen motor and trans mounts and jack the engine up as high as you can. Also don't forget the strut tower brace if you have one
Billgluckman is offline   Reply With Quote
exhaust
Exhaust flange gasket 1996v6stang 1996-2004 Mustang GT 11 01-12-2013 05:57 PM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 11:51 AM
EXHAUST GASKET joeysull Classic Mustangs 2 03-29-2011 05:33 PM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 03:24 AM
exhaust gasket bigpomps Pre-2005 V6 Mustang 5 04-09-2006 06:49 PM
10:14 PM
