Goods and Bads - Mustang Evolution
Old 10-28-2014, 07:27 AM   #1
bigmac3's Avatar
Goods and Bads
Now that I have already bought one, what are the goods and bads of the New Edge GTs. The looks of it have to top the goods list.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 10-28-2014, 07:38 AM   #2
Eturner's Avatar
What year Edge did you get?..
Old 10-28-2014, 07:40 AM   #3
bigmac3's Avatar
Originally Posted by Eturner View Post
What year Edge did you get?...
2002
Frank
Old 10-28-2014, 07:55 AM   #4
Mile high JDF's Avatar
Well the spark plugs have a tendency to leave their homes if over torqued even just a little bit. You should have the revised intake manifold but they do still end up leaking on occasion. The 3650 Trans was over filled from the factory so if the car is a manual and hasn't had the trans fluid replaced then make sure to do that and fill it with 3.2qts I stead of going until it spills out of the hole.
Those are really the only 3 things I can think of right now. Post up some pics when you get a chance. Are you planning on moving it or just using it as a driver?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-28-2014, 08:29 AM   #5
V6 stang's Avatar
Goods and Bads
Great motor but slower now since it is like 12 years old.. Interior is crappy
Pretty much everything is said above. Rest will be more opinion than anything.
Seat belt retractors need their mechanisms changed normally, they start to not retract lol.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 10-28-2014, 09:55 AM   #6
bigmac3's Avatar
Not exactly sure what it's role will be. I just think they are cool and when that generation was new, I wasn't able to own one. Is it tunable with a hand held or is still of the "replaced chip" type? Here are some shots. It is missing it's tailpipes and sounds rather nice. I have to figure out how to bring them all the way back without losing that sound.
ID:	168685   Click image for larger version
Frank
Old 10-28-2014, 10:02 AM   #7
V6 stang's Avatar
Nice ride. No tail fin too, cool! You'll have to see/know the set up before we can tell you how to keep it but throw it out the back. You'll probably just have turn downs with stock mid pipe. Unless it's like hella loud. If it's really loud then you may have a mid pipe
Roush Exhaust
Old 10-28-2014, 10:16 AM   #8
You can do a hand held tuner like the newer cars. My guess is they lopped off the mufflers and dumped it, or just took off the catback.
Old 10-28-2014, 11:51 PM   #9
2 questions that pop into mind..... Are there any holes in your deck lid? And is that grille factory? Only 99-04s I know of that come with a black grille surround were the Bullitts, unless that one has been painted or dipped.
Old 10-29-2014, 07:10 AM   #10
bigmac3's Avatar
Yes, there are holes and yes, I believe it's dipped. I'd run out and check it but it's still at the seller's as I have not been able to get help in getting it home. My son is going to weld the holes shut and repaint the trunk lid. I will probably clean the dipped grille/pony. I generally like spoilers, but the only one I like for the New Edge is the one for the Cobra. I think that I actually like the clean look better.
Frank
Old 10-29-2014, 11:28 AM   #11
Steve96's Avatar
That car looks great. I like it.
1996 GT
Old 10-29-2014, 12:13 PM   #12
bigmac3's Avatar
Frank
Old 10-29-2014, 02:49 PM   #13
Cbird's Avatar
Region: Iowa
Same here but it's ~600 bucks. The Saleen one is a good compromise but not as clean as the cobra spoiler.
Cbird is offline   Reply With Quote
Old 10-29-2014, 02:56 PM   #14
bigmac3's Avatar
I have found a few on ebay for $450-475, still high when you compare it to the ones for the '10-'14s.
Frank
Old 10-30-2014, 11:23 AM   #15
Slow4V's Avatar
Good - Everything lol
Bad - intake manifolds leak , could get pricey if you want to get more than 300rwhp. Imo
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-30-2014, 12:28 PM   #16
bigmac3's Avatar
Glad to hear "Everything" is good. Yeah, I've heard about the manifolds. It's only going to be a fun daily driver. Stock hp is just fine.
Frank
Old 11-01-2014, 12:58 PM   #17
green calipers?
Hello is offline   Reply With Quote
Old 11-01-2014, 02:03 PM   #18
The outside "skin" on the deck lid is not metal. It is a composite material, the same with the hood.
So don't bother trying to weld the holes shut.
Old 11-01-2014, 03:13 PM   #19
bigmac3's Avatar
Originally Posted by Hello View Post
green calipers?
Can't explain that, and only on one side???
Frank
Old 11-01-2014, 03:15 PM   #20
bigmac3's Avatar
Thought that felt kind of odd. I wonder if the cobra spoiler will cover both sets of holes left by the stock wing?
Is this Mach1000 sound system, OEM? Sounds pretty nice but finds all your rattles very quick.
Frank
Old 11-01-2014, 03:27 PM   #21
Yea the Mach 1000 was the highest option. Its like the Shaker 1000 they called it in newer ones. And the lastest they call it is the Shaker Pro Audio. Its the highest level that came in the car. Most common is Mach 460, which is the same thing, just none of the trunk set up.
Old 11-04-2014, 08:08 AM   #22
bigmac3's Avatar
OK folks, the car has finally made it home and I spent the last few days working on it.
First, I changed the oil and filter, tranny fluid (total flush) and filter, and bought new tires. I went my own way here. Instead of replacing them with 245/45-17s like they had, I went with 235/60-17s. These are the same size that my '11 V6 came with new. They are taller and fill the wheel well nicer. Speedo is off a bit but that will be fixed with a tuner.
Next, the exhaust system. The previous owner had installed 3" mid pipes to a pair of Flowmasters. That's it. These just dumped out in front of the rear axle. They sounded great outside the car and from a distance but were a nightmare to drive with. I went to my local muffler shop and had them install tail pipes with really nice generic 4" tips. It is now a pleasure to drive and it looks and sounds great.
Finally, I have a friend who owns a wrecker service. As it turns out he had in his impound lot, an abandoned 2000 Fobra. Unfortunately both front and rear bumpers were torn and not usable, but the spoiler/trunklid, front grille and driver's seat were all perfect and I got them all for $100.
All that I have left to do now is a CAI/tune and paintjob and possibly gears. Woohoo!
Frank
Old 11-05-2014, 08:04 AM   #23
fenixignition's Avatar
Only "bads" i can think of about em is the firewall doesnt block much sound. the shifter is sittin right on top of the transmission, as opposed to the way it sits in the newer models, so tranny noises. I think a lot of them have a rattling/grind sound in 5th gear, which is shrugged off as normal. mine does it when the fluid is cold. the dash tends to have a rattle which is easily fixed, and thats just buy pulling the fascia off, and sticking something behind it and putting it back on. but if your listening to music or just driving fast, then all this probably goes unnoticed.
otherwise, bulletproof car. got mine with 139k miles, likeley beaten on, still strong.
Old 11-05-2014, 08:10 AM   #24
bigmac3's Avatar
I've got an auto, so no prob on those tranny quirks. Yes, I've noticed the squeaky dash and it tends to buzz at times with the radio. I have a broken radio bezel with a new one on order, so I hope that fixes that problem.
Frank
For Sale: Two 10 inch pioneer subs and amp and wires and box NicholasP Mustangs for Sale and Wanted 4 05-07-2013 08:59 PM
The Mailman Came Wit My Goods bluemustang The Bar 9 04-19-2007 02:00 PM
Fox Body '89 and 16" and 17" wheels and rims Kevin Brown Mustang Wheels & Tires 12 11-10-2005 05:56 PM
02:16 AM
