Inside tire tread is wavy. - Mustang Evolution
Old 10-28-2014, 08:08 AM   #1
Kbasham5's Avatar
Hey guys quick question. I installed some lowering springs in my 2001 GT and now the tires are wearing on the inside. The wear is really wavy. You can run your hand on the inside of the tires and you can feel it going up and down. Will the camber being out cause this?
Thanks
Kbasham5 is offline   Reply With Quote
Old 10-28-2014, 08:29 AM   #2
It's not me, it's you.
primer2tone's Avatar
That's odd. After lowering my car I got some pretty heavy camber wear on the inside but it was smooth.
Maybe the toe is off too? Either way, you need to get a couple of tires and get that alignment set. If anything else is wrong or wore out, they'd be able to tell you once they get it up on the alignment rack.
Old 10-28-2014, 08:41 AM   #3
Slow4V's Avatar
That's camber wear
Your alignment is bad.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 10-28-2014, 08:42 AM   #4
Site Sponsor
Thanks
Can you post up a picture of the wave you're talking about? Has the car been aligned? I think it might be high time to pick up some cc plates-I ran J&M's Caster Camber Plates on my Bullitt with a 2" drop and never had and issues after the fact and they should clear that up for you! Let me know if you have any questions and I'm here to help!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 10-28-2014, 10:19 AM   #5
Mile high JDF's Avatar
Sounds like toe wear to me, it may have some camber wear too but the wavy part is definitely toe
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-28-2014, 08:10 PM   #6
thyreaper's Avatar
Well when u change the camber like that it throws the toe out as well thats why when u do an alignment u set the caster/camber first then u set the toe ( im an alignment tech for goodyear ) also have u ever changed the shocks/struts? If they are old and worn out they could also cause cupping/feathering of the tires but either way u need some cc plates to properly set the camber/caster on our cars so start with that then go get ur alignment done and if ur shocks/struts are old it would be wise to change them out to ( i have tokico shocks/struts and are happy with them )
thyreaper is offline   Reply With Quote
Winter tread how low? jomcgui 2011-2014 V6 Mustang 0 10-07-2014 01:12 AM
Tread life on uhp summer tires? KSconvert Mustang Wheels & Tires 16 03-24-2014 04:51 PM
New sumitomo tire strange tread wear maverick214 Mustang Wheels & Tires 8 07-01-2013 08:01 AM
Another tire tread Midnight Mustang Wheels & Tires 0 03-31-2013 03:48 PM
Spark Plug Tread Stripped 504 Stang Rida 1996-2004 Mustang GT 0 03-26-2012 09:34 PM
10:12 PM
