2000 GT trans refill - Mustang Evolution
Old 10-29-2014, 02:54 PM   #1
XSlashDashX's Avatar
After putting the catback on my GT i noticed my trans was leaking. Looked further up and saw the gasket was not sealing properly. Previous owner put a short throw in and i assume a gasket off of americanmuscle because the gasket is orange. Anyways i bought 4 quarts of pennzoil syncromesh and permetx ultra black. I've never drain trans before. And i see 2 bolts on the trans. The bottom is to drain of course. Can i refill from the shifter? And 3.2 quarts is recommended?
Old 10-29-2014, 03:19 PM   #2
The_Chech's Avatar
You can refill from the shifter. And it's really easy to drain the transmission almost like doing an oil change really just a few more things involved.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-01-2014, 06:53 PM   #3
Thanks! Got it done today and man does it shift 10x better. Going in Reverse was easy then ever! I used 3.2Qts Pennzoil Synchromesh and rtv gasket seal. I highly recommend no one to use the orange gasket from AM (Mustang Shifter Base & Handle Gasket (82-04 V8; 93-01 Cobra; 94-04 V6) - Free Shipping) Because that's what cause my leak in the first place. I pulled my shifter off and that gasket was pushed out from the shifter. I did not put it on but I know now not to use one of those gaskets.
Old 11-02-2014, 06:59 PM   #4
Those gaskets always squeeze out and it leaks after awhile. The AM ones are knock offs of the "Cobrabob" gaskets but those leaked on me too when I used them. Always just did black RTV and it never leaked. And yes, pennzoil syncrhomesh is the ****.
Old 11-05-2014, 09:38 AM   #5
fenixignition's Avatar
yea sometimes when pullin on the shifter for a quicker shift, i notice the smell of transmission fluid. i think i got lazy the last time i put rtv on it. theres mobil 1 synthetic mercv in there now, and i have no issues with shifting. i was on the fence about putting that pennzoil synchromesh in. anyone know if its better than mobil1 or about the same?
Old 11-05-2014, 01:48 PM   #6
If you have no issues with shifting I'd leave the M1 in there. However if you notice its a little notchy or is hard to shift when cold, give the Pennzoil a shot.
Radiator refill Polar Bear 1996-2004 Mustang GT 5 08-16-2013 07:21 AM
2000 gt manual trAns mission Ponyup 1996-2004 Mustang GT 4 07-09-2012 09:37 PM
Convertible Top Motor/Pump Fluid Flush/Refill FYI POST runvsofthisbull 1996-2004 Mustang GT 0 06-23-2012 01:12 PM
DOHC Refill & Burp Procedure jm@ReischePerf 1996-2004 Mustang GT 3 09-30-2009 07:09 PM
2001 Mustang GT coolant refill? lysander 1996-2004 Mustang GT 2 08-25-2009 02:15 PM
11:33 AM
