No thermostat? - Mustang Evolution
Old 10-29-2014, 11:41 PM   #1
cstyle408's Avatar
No thermostat?
I went to replace my thermostat and when i opened up the housing there was no thermostat to replace. Why would someone run this car with no thermostat??
98 Mustang GT 5 speed
cstyle408 is offline   Reply With Quote
Old 10-29-2014, 11:53 PM   #2
Tyoung68's Avatar
If it got stuck it could cause a car to over heat so if you got stuck somewhere you could take it out and and drive it again
Killing time isnt murder, it's suicide
Old 10-30-2014, 12:48 AM   #3
cstyle408's Avatar
That makes sense. Ive been driving it around for over 6 months not knowing there was no thermostat. I bought the recomended temp therm. I read that its not good to run no thermostat in these cars
Old 10-30-2014, 05:50 AM   #4
thyreaper's Avatar
No thermostat?
Naw u could run no thermostat it just it take forever to warm up and what ppl dun realize that it also helps cool because after it opens it will then again close trapping /slowing down most of the water in the radiator to cool down then once it gets hot again ( enough to open) it opens and lets all that cool water that was trapped in the radiator into the motor, now will it run hot without one, not usually but it would make warming up take alot longer especially if its very cold outside all in all its good to have the thermostat because it helps maintain one temperature
thyreaper is offline   Reply With Quote
Old 10-30-2014, 06:18 AM   #5
bucko's Avatar
Not wise to run without a thermostat. The engine is designed to burn the fuel at a certain temperature, so the ECU/PCM mappings will constantly be trying to compensate for the wrong engine temps. This will effect your MPG. Your oil will contaminate quicker as well, as a cooler engine will not burn out any condensation from the oil that can collect.
Its also going to be a higher polluter.
Old 10-30-2014, 07:01 AM   #6
They do make thermostats that have fail safes built into them so that if they are broken they freeze in the open position to prevent overheating.
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 07:30 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 09:17 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 07:41 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 12:00 PM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 03:08 AM
08:27 AM
