clunk - Mustang Evolution
Old 11-01-2014, 07:41 AM   #1
clunk
when my wheel is turned and I back out or pull in somewhere I get a clunk like as if I ran something over. Feels like it is coming from the passenger side front. When I look around, everything seems to be intact however the boot on the drivers side is ripped. Would this be causing the problem?
Hello is offline   Reply With Quote
Old 11-01-2014, 08:08 AM   #2
Actually its not the boot, its beside the boot looks like greese is built all up on that one part
Old 11-01-2014, 10:35 AM   #3
Region: Iowa
have u checked inner tie rods they will pop when braking and turning some aftermarket control arm bushings will pop back and fourh on bolts because no surated sleeve to bit in after tightening bushing
derry96gt is offline   Reply With Quote
Old 11-01-2014, 12:32 PM   #4
Check the bushings on the steering rack... Particularly the one on the drivers side near the boot that is in the picture.
Old 11-05-2014, 06:05 AM   #5
fenixignition's Avatar
jack the front end up, (use jack stands and proper safety)
grab the wheel at 9 and 3. try to shake it, pushing both sides alternately. (there will be some play because the wheels will turn with the steering. your feeling for the tie rods being loose.
next grab 12 and 6. same thing, push the top and bottom alternately. it should be pretty stiff. if its knocking around, then likely your ball joints are shot.
a bet´┐╝ter way to check the tie rods, is to lift the car off its suspension but the tires still gripping the ground a little bit.
steering rack being loose should give you more of a wandering on the road feeling. popping or knocking sounds like ball joints/tie rods tho.
Trunk clunk from bumps Macluva18 Pre-2005 V6 Mustang 10 11-20-2011 10:11 AM
Loud Clunk V6Mustang40th Pre-2005 V6 Mustang 6 11-12-2011 12:00 PM
Occassional "clunk" on start up flash4353 Pre-2005 V6 Mustang 12 10-11-2007 06:12 PM
2004 Ford Mustang - clunk? lisalulu Pre-2005 V6 Mustang 7 05-08-2007 08:01 AM
04:11 PM
