Bake Light - Mustang Evolution
Old 11-01-2014, 09:35 PM   #1
Bake Light
Alright so my brake light comes on randomly when either accelerating hard or braking hard. If any of you recall the brakes have been thoroughly bled recently. The fluid isn't low. The car brakes perfectly fine so that isn't worrying me, its just the light thats got me confused. Any ideas?
Old 11-01-2014, 10:34 PM   #2
Slow4V's Avatar
Could be something in the abs , or brake light switch may be going out. Imo
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-01-2014, 10:53 PM   #3
+1 on the switch. Must be a sensor. They're usually not too much anyways
Judge_dredd is offline   Reply With Quote
Old 11-01-2014, 11:33 PM   #4
I asked a few other places and people are saying the switch/sensor also
Old 11-03-2014, 09:40 AM   #5
Yellastang03's Avatar
I had the same thing happen to me but it was because my pads were extremely low and too much brake fluid would be compressing caliper pistons. Although my master cylinder was at the correct level of brake fluid. I did breaks and rotors and it went away. To explain it under hard acceleration I was suggested my break fluid could be low just enough that when I accelerate hard it would cause it the fluid to splash around in my master cylinder causing the brake light to temporally to come on. Check your pad levels, bleed your brakes.
Yellastang03 is offline   Reply With Quote
Old 11-03-2014, 12:26 PM   #6
Pads have only a few hundred miles on them. And fluid level is good.
Old 11-07-2014, 06:07 AM   #7
thyreaper's Avatar
Prolly the level sensor inside the brake master cylinder res, if ur abs lights come on to tho then it could be the abs/brake control module ( if no abs lamp then i would not even worry about the module) i may be wrong but i think u can unplug ur level sensor and the lamp will stay off which might confirm the level sensor but again i may be wrong but i think thats what i did on my gf 97 cuz her level sensor float had a hole in it somehow and would not float up and the light was annoying untill i had time to fix it, also thats another thing, is ur level sensor float rising to the surface?
thyreaper is offline   Reply With Quote
Old 11-07-2014, 06:49 AM   #8
fenixignition's Avatar
the braking and acceleration sounds like the sensor to me. mine was like that when i bought it. added some fluid up to the neck and never happened again. but if yours is filled all the way to the point that movement of the fluid wouldnt change the elevation of the sensor, my guess would be a faulty sensor or plug/wire. a friend of mine said it could be the plug in the e-brake handle, when we were working with a camry.
Old 11-07-2014, 10:47 AM   #9
The whole ABS system has less than 2 years on it so I'm sure it's not that. Probably is the sensor.
Old 11-07-2014, 04:17 PM   #10
thyreaper's Avatar
Yea but theres always the possibility thats why i mentioned it but if the abs lamp isnt coming on with it then thats not it, and yes it could also be the sensor in the ebrake handle as well but thats usually rare ive never had to replace one... Make sure ur float in the res is indeed floating lol
How To: Paint Your Headlights in 15 Easy Steps (oven bake method) Topless04GT Mustang Paint, Appearance & Detailing 6 12-11-2011 05:46 PM
Press O/D button or accelerator break fluid light and seat belt light blink Bgover Pre-2005 V6 Mustang 11 04-02-2011 09:52 AM
The Service Engine Light Soon light is on!! HELP! punisher0822 1996-2004 Mustang GT 11 07-15-2010 11:15 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 03:21 PM
Green Light, Red Light Brent Pictures and Videos 11 01-24-2008 05:23 PM
06:56 PM
