Bogging , kind of misfiring - Mustang Evolution
Old 11-02-2014, 02:04 PM   #1
Slow4V's Avatar
So today after I was cruising , hauling *** I suppose. I was cruising back and noticed I was kinda Mis firing .. came home checked my coils and had a little water in them , blew them off with a air gun. And still missing. .
Scanned my codes and it threw a code for exhuast gas circulation low or something , cleared it and it ran okay .. but now I'm at the tattoo shop and won't drive it for a couple hours .. any thoughts ?
Spark plugs are new.
Mods - full exhaust , intake , manifold spacer , gears , mpt tune , etc.
Any ideas ?
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-02-2014, 03:18 PM   #2
Slow4V's Avatar
1st and 2nd are good .. but when I hit 3rd or 4th it starts bogging like it doesn't want to go faster than 70
Old 11-02-2014, 06:47 PM   #3
The_Chech's Avatar
Possibly the tune? Not really sure
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-02-2014, 08:12 PM   #4
phillip433's Avatar
Does it seem like you hit a rev limiter or some sort? It possibly could be camshaft or crankshaft sensor if that's the case.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 11-02-2014, 08:39 PM   #5
Slow4V's Avatar
Hmmm crank or cam would throw a code , and would be turning the car off. So doubt that's the issue.
---------- Post added at 10:39 PM ---------- Previous post was at 10:39 PM ----------
Reloaded the tune earlier. Have to drive 50 miles before I can go wot so hope that helps ..
Going to clean maf and change fuel filter too , maybe it's bad Gas ?
Old 11-05-2014, 07:50 PM   #6
1996mustang's Avatar
Alty? Just a thought could be a diode goin bad. Check again for water like u found earlier if its building up start finding a leak. Tps also would do something like it and not throw a code as well. Just my 2ยข
Old 11-07-2014, 12:09 AM   #7
thyreaper's Avatar
Crank and cam sensors would throw a code more then likely but the cam sensor would let it run just run poorly, i dont think those 2 are ur issues tho i think the water in the spark plug holes was ur prob even after u blew it out it could of still had some moisture in there still and also the plugs could have gotten alil flooded/fould with the missing, id try and figure out why and how u got water in ur spark plug holes if u have intake leaking that could be ur sole issue
thyreaper is offline   Reply With Quote
Old 11-09-2014, 03:28 PM   #8
Slow4V's Avatar
Turned out to be fine , after resetting tune and putting new gas. Think I had bad gas
Old 11-09-2014, 05:29 PM   #9
Speed_Mister's Avatar
Region: Arkansas
Yeah, you may wanna keep an eye out on those coils that had water in them. If you have problems like that again I'd replace the coils that had any moisture in them.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
99 mustang misfiring during hard throttle 1quick4.6 1996-2004 Mustang GT 5 02-28-2012 11:53 AM
EVAP Help P0455 CEL and now random misfiring 3ntr0py Pre-2005 V6 Mustang 11 01-24-2012 01:37 PM
Misfiring problems Stockish302 1979-1995 Mustang GT 14 11-15-2011 01:08 PM
misfiring need help austinknoll Pre-2005 V6 Mustang 11 08-17-2011 12:27 AM
Cylinder Misfiring? Jeremym831 1996-2004 Mustang GT 4 02-05-2008 12:12 PM
11:08 PM
