2000 Mustang GT won't full throttle - Mustang Evolution
Old 11-03-2014, 11:13 AM   #1
I have a 2000 Mustang GT, runs great until aggressive with full throttle and falls straight on it's face and bogs down. If your very easy with throttle it is better but once above 3000rpm or around there. Anyone have ideas?? Throttle position sensor new.
Modularcrazy is offline   Reply With Quote
Old 11-03-2014, 11:36 AM   #2
You possibly have a fuel delivery problem. Replace the fuel filter and if that doesn't help, do a fuel pressure test.
Old 11-03-2014, 11:44 AM   #3
Thanks, I was leaning towards that but filter and fuel pump are new. May have some some stuff breaking down in gas tank. Injecters are new as well. Did sit for a few years
Old 11-03-2014, 11:46 AM   #4
Panther140's Avatar
Remove all of the EFI **** and put a god damn carburetor on it and msd ignition. The beauty of keeping it simple will show up every time you want to do a mod or adjust anything and it doesn't cost you hundreds to re tune it and then another few hundred for bigger injectors and all of that. Throw a supercharger on in your garage and do a WOT pull right out of your driveway! imagine that
Panther140 is offline   Reply With Quote
Old 11-03-2014, 11:56 AM   #5
Ok.
Another thing to check is the charging system. It can be charging enough to keep the battery charged to start the engine but not enough to run the computer. It can cause all sorts of driveability problems.
Also, scan for any codes. There may be some even if the Check Engine Light is not lit up.
Old 11-03-2014, 11:58 AM   #6
Good luck trying to get it to pass emissions testing.
Old 11-03-2014, 12:04 PM   #7
I think your right on fuel delivery, I have checked it with my actron cp9185 scanner and there are no codes or misfires.
Old 11-03-2014, 04:55 PM   #8
Panther140's Avatar
Idk where they do that at but it certainly isn't where I live. Damn gestapo Nazis regulating the **** out of everything. We seriously need another good ol fashioned revolution.
Old 11-04-2014, 01:23 PM   #9
Billgluckman's Avatar
Check your fuel pressure, report back.
Billgluckman is offline   Reply With Quote
Old 11-05-2014, 05:49 PM   #10
thyreaper's Avatar
If fuel press is ok try cleaning the maf its possible that its so dirty that it cant read right to report correct load
thyreaper is offline   Reply With Quote
Old 11-06-2014, 07:04 PM   #11
V6 stang's Avatar
Lol good luck.. Our police are armed like the military and will flash bang your ***. We live in an interesting time for sure.
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 11-06-2014, 11:01 PM   #12
Panther140's Avatar
Hence the "Gestapo" reference. Our police are not here to protect us anymore. Its dangerous that nobody is realizing that.
News flash for everybody: The government does not have empathy. The thing that is most precious to any government is its power over the people that it rules. That is the number 1 concern.
Old 11-06-2014, 11:42 PM   #13
thyreaper's Avatar
Also im not for a carb setup, anytime weather changes u have to change jetting if u have a boosted carb setup, and these 2vs just dont make enough hp n.a for me to be content
Old 11-07-2014, 05:00 PM   #14
Panther140's Avatar
Ehh, if the weather changes like 60 degrees, then you have to. And its really easy to re jet a carb idk why everybody thinks messing around with EFI is easier. It is easier to re jet the carb once or twice a year than it is to jump through the 50000000000 hoops that you have to do to make an EFI system feed a forced induction engine.
Plus, carbureted throttle response > Anything else. Don't even get me started on Drive by wire
Old 11-11-2014, 05:54 AM   #15
Replaced fuel filter last night and that took care of the problem. I overlooked that since it was just changed a few months ago. Thanks
Old 11-11-2014, 05:57 AM   #16
Changed fuel filter last night and that fixed it, no problem with throttle now. Thanks
Old 11-11-2014, 10:11 AM   #17
fenixignition's Avatar
did you (safely) cut it open and look at all the gunk? what color was the fuel that fell out of it? was it a nice dark brown roast, or more of a rusty orange?
2002 GT 5sp. 16x,xxx miles
Old 11-11-2014, 02:55 PM   #18
Dark Roast, I'm sure the gas was tarnished some from sitting for so long before i bought it but this is the second fuel filter and 3rd tank of gas with new fuel pump.
2000 mustang
Car won't crank.... full story inside. Black_Sunshine Pre-2005 V6 Mustang 0 08-22-2012 04:07 PM
Factory 2000 Mustang - won't start Help :( mistysblaze2000 Pre-2005 V6 Mustang 7 02-21-2011 01:47 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
Valves sound like they rattle at full throttle dch61407 1996-2004 Mustang GT 4 01-27-2008 06:28 PM
History Channel, Full Throttle, Mustangs! WhiteStang99 The Bar 6 11-10-2004 07:49 PM
04:18 PM
