Panhard bar - Mustang Evolution
Old 11-05-2014, 02:55 PM   #1
The_Chech's Avatar
Panhard bar
So I bought what I hope to be a full Maximum Motorsports pan hard bar for really cheap. The guy totaled his car and was parting things out. Needless to say he never installed it and it's brand new. I took pictures of every thing he had for it. But am I missing any thing?Click image for larger version
Name:	ImageUploadedByMustang Evolution1415224425.126320.jpg
ID:	169242Click image for larger version
Name:	ImageUploadedByMustang Evolution1415224451.870054.jpg
ID:	169243Click image for larger version
Name:	ImageUploadedByMustang Evolution1415224481.453403.jpg
ID:	169244Click image for larger version
Name:	ImageUploadedByMustang Evolution1415224504.925367.jpg
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-05-2014, 02:58 PM   #2
Panhard bar
I believe that is all of it. I would have to go back and look at pics of when I put in my Panhard Bar. But from what I remember during install that looks like all of it.
They also have instructions on their site if you want to take a look.
Old 11-05-2014, 03:01 PM   #3
The_Chech's Avatar
I was about to ask that lol but it doesn't look hard to install. Does this require any drilling though?
Old 11-05-2014, 03:03 PM   #4
Yes it does. You have to drill through the frame and the parts that mount to the frame (U parts at the ends), I'd recommend a heavy duty drill and some muscle, the frame is easy but the part on the chassis mount is a *****.
Old 11-05-2014, 03:08 PM   #5
The_Chech's Avatar
Another question I have for Soccer is, will this even work since I'm so low now or is it going to bind? I know the bar is adjustable but not sure by how much.
Old 11-05-2014, 03:11 PM   #6
All the pics I have of install
Name:	ImageUploadedByMustang Evolution1415225096.630197.jpg
Name:	ImageUploadedByMustang Evolution1415225103.724790.jpg
Name:	ImageUploadedByMustang Evolution1415225483.448223.jpg
Old 11-05-2014, 03:12 PM   #7
It will work. The bar is adjustable by screwing in and out, so it will work with pretty much all set ups.
Old 11-05-2014, 04:11 PM   #8
The_Chech's Avatar
awesome well I know what I'll be doing this weekend.
Old 11-05-2014, 04:20 PM   #9
It helps if you have a helper, because you have to hold the brace while you mark and drill it.
Old 11-05-2014, 05:43 PM   #10
The_Chech's Avatar
So I've been doing a bit of digging into more on what else I can do in conjunction with the rear suspension with the installation of the panhard bar. It seems a few other people on different forums have removed the driver side Upper control arm and have either left the stock one until its gets weaker and then replacing it with some other brands of upper control arms and a few have highly recommended the TRZ uca with a spherical housing bushing. Basically it reduces the compression and then tension on both which creates the binding issues and makes it more uniform. So with the panhard bar installed and one upper control arm removed it creates like a poor mans 3-link so it seems.
Any one heard of this being done?
Old 11-05-2014, 06:46 PM   #11
Yea I've seen that done before. You will need to reinforce the torque box of the one you keep though. I highly recommend just doing it right and getting a Torque Arm to convert to a 3 link.
Old 11-05-2014, 07:19 PM   #12
The_Chech's Avatar
Trying to go that route this winter before warm weather hits again. Along with a few other things and possibly just getting the whole suspension done with honestly.
Old 11-05-2014, 08:51 PM   #13
It all makes a huge difference. After i was finished with the Subframe Connectors, LCAs, Panhard Bar, and Torque Arm my rear end was so much more in control. I could hit the gas much more in corners and jerk the wheel a lot harder without the rear end wanting to step out. Actually the car was more on the understeer side. Even in the slalom i could jerk the wheel and not have the back end step out.
Old 11-06-2014, 04:43 PM   #14
Lapida's Avatar
Do You have 2.5" diameter exhaust with the panhard bar in place?
Lapida is offline   Reply With Quote
Old 11-06-2014, 05:00 PM   #15
I have a stock catback (Different mufflers welded in, but stock piping). I have heard that with some aftermarket catbacks there can be clearance issues with the chassis brace. Mine was pretty damn close already.
Old 11-07-2014, 08:33 AM   #16
The_Chech's Avatar
Glad I have side exhaust to put this on
Old 11-08-2014, 02:51 PM   #17
The_Chech's Avatar
Okay so I'm at the part that you have to drill into the frame. The part that's confusing me is that you only drill on the out side of the frame? At least that's what MM has in the instructions and I have to say their instructions are terrible.....
I'm Half tempted to drill through the whole frame and bolt it straight through. That way its securely bolted all the way through and not just on the out side half of the frame.
Old 11-08-2014, 02:55 PM   #18
You only drill through the outside part because that is where you install the 2 silver inserts with the 2 prongs on each. Those go into those holes and then you put the chassis brace on the outside of it and install the nuts through the brace and through the opposite ends of the prongs with the openings. Essentially what that is, is making the frame more sturdy where it mounts. And it has a threading effect through the inserts.
Old 11-08-2014, 03:08 PM   #19
The_Chech's Avatar
Not sure how I dont understand this one still. Because the way im envisioning it is that there is no way you get a nut into the frame.
Good Aftermarket Panhard Bar? Skinsfan6 2005-2010 Mustang GT 7 03-05-2010 10:07 AM
rear sway, or panhard bar? A5295 1979-1995 Mustang GT 12 07-16-2007 08:05 AM
panhard bar eagle05 1979-1995 Mustang GT 12 07-09-2007 08:03 AM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
Panhard Bar Question njstang97 Pre-2005 V6 Mustang 6 11-07-2004 11:31 PM
04:38 PM
