Scavenging (Cam Profiles) - Mustang Evolution
Old 11-05-2014, 10:39 PM   #1
ANS
Send a message via Skype™ to ANS
I have been reading a lot about different cam profiles and the different effects etc. Our 4.6 2v motors do not rev safely too high in stock form. Would any scavenging (even a minor overlap of the cam) help our motor or is it really only for a higher rpm range?
ANS is offline   Reply With Quote
Old 11-06-2014, 06:49 PM   #2
I think that the sort of cam profile that you are referring to would be more for the upper RPM range and you would actually lose some power at lower RPM's.
Old 11-06-2014, 11:47 PM   #3
thyreaper's Avatar
Yea and unless u have a good lower intake ( like mr bullitt there his car comes with one ) u wont make good hp at higher rpm because the plastic pi intakes are good intakes up till about 6500 rpms after that they tend to die out so unless u are planning on a better intake and a high revving motor build id stay away from the higher operating range cams
thyreaper is offline   Reply With Quote
Well the RPM heads and cam are installed!!!! Danger Dude Pre-2005 V6 Mustang 4 10-14-2008 06:53 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
Cam Install ? dapack69 Pre-2005 V6 Mustang 6 09-04-2003 01:40 AM
01:09 AM
