96-98 cobra intake cams - Mustang Evolution
Old 11-06-2014, 04:09 PM   #1
03Graymach's Avatar
I found a guy selling parts off his 97 cobra I'm am going to buy the intake cams from him are there any other parts I need to get from him for the swap
03Graymach is offline   Reply With Quote
Old 11-06-2014, 04:50 PM   #2
1996mustang's Avatar
If your doin a 4v swap might as well get the whole motor. What is your plan on the swap?
Old 11-06-2014, 05:35 PM   #3
03Graymach's Avatar
I'm have a Mach 1 already a 4v but putting the 96-98 intake cams adds 20 degrees of duration and because that you get more hp
Old 11-06-2014, 06:08 PM   #4
Slow4V's Avatar
Just use the intake cams , not the exhuast cams.
You should see 20rwhp with no degree
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-06-2014, 06:46 PM   #5
03Graymach's Avatar
Yeah I knew not to use the exhaust was not sure if I need anything else like the sprockets or things like that
Old 11-06-2014, 07:48 PM   #6
Ah ok i see now i learned something new
Old 11-06-2014, 08:47 PM   #7
Slow4V's Avatar
Na , should be good to go.
Lucky .. lol I'm hunting for them myself.
Old 11-07-2014, 07:42 AM   #8
03Graymach's Avatar
Lol yeah been trying to find them for over a year and just happened to find a guy redoing everything on the top end of his 97
Old 11-07-2014, 09:04 AM   #9
Slow4V's Avatar
Nice , just make sure the lopes aren't messed up.
What's all done to your mach 1?
Old 11-07-2014, 09:49 AM   #10
03Graymach's Avatar
BBK ceramic long tubes BBK o/r x pipe slp loud mouth cat back and sct chip
Old 11-10-2014, 07:02 AM   #11
Lol they come up for sale on the corral all the time.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 11-17-2014, 07:09 AM   #12
phillip433's Avatar
I see people do this all the time to their 4v. Why not just by better cams? Is it because it's just cheaper to get it from a 98 cobra?
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 11-17-2014, 09:18 AM   #13
Because they are really cheap and give a half decent power bump.
Old 11-17-2014, 11:44 AM   #14
Lorraine's driver
ab_mach1's Avatar
They also drop low end torque a tad. Most say they think the gains up high are worth it though. I would definitley degree the cams though. IMO, I'd rather upgrade if I'm opening up my heads. Either way though, it's a nice bump.
Instagram: @ab_mach1
Old 11-17-2014, 12:18 PM   #15
phillip433's Avatar
That's what I'm saying. That much work it seems like I would just go ahead and put aftermarket cams or some sort.
Old 11-17-2014, 12:29 PM   #16
You really don't even need to add any cams, plenty of stock longblock Cobras in the 700+ range although at that point the pistons become a little suspect from everything I've read. And lots of them are KB/Whipple cars so low end is not going to be any sort of concern.
Old 11-18-2014, 06:31 AM   #17
03Graymach's Avatar
My reasoning is these are 150 for 20 hp or I can spend a 2 grand after all the parts and get a little more than 20
Old 11-18-2014, 11:13 AM   #18
phillip433's Avatar
Hey either way, you have better cams.
Old 11-18-2014, 02:58 PM   #19
This ^^^^^^^^^^^^^^^^
Old 11-18-2014, 03:00 PM   #20
Yea if you are going for numbers then just 96-98 cobra cams and then boost it. If you want more revs then aftermarket cams, but after 7k the Mach 1 intake needs replacing.
Intake Manifold and CAms for 2000 gt exceso 1996-2004 Mustang GT 14 09-23-2013 04:56 PM
Boss intake or Cobra Jet intake Nickmarlow 2011-2014 Mustang GT 30 05-29-2013 05:57 PM
Cams and intake manifold MustangGT02 1996-2004 Mustang GT 6 05-21-2013 08:08 PM
94-98 Cobra Cams Swap? TtownMach1 Other Special Edition 1 04-22-2012 09:40 PM
Heads, Cams, Intake 2kslvrgt 1996-2004 Mustang GT 19 03-13-2009 10:33 PM
06:12 AM
