Squeaky clutch? - Mustang Evolution
Old 11-09-2014, 05:29 PM   #1
HighlyBored's Avatar
Squeaky clutch?
Just noticed today that when I depress my clutch it makes a very audible squeak on the way down. Works just as normally as it always has, just squeaks. Kind of like a bird's chirp almost. The hell is that?
HighlyBored is offline   Reply With Quote
Old 11-09-2014, 05:31 PM   #2
Speed_Mister's Avatar
Region: Arkansas
Throw out bearing. Mine does it to. I just ignore it, it doesn't hurt nothing.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-09-2014, 05:34 PM   #3
Yea I'm not really concerned because it feels just fine just didn't know what was causing that. Thanks though!
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-09-2014, 07:05 PM   #4
fenixignition's Avatar
One quick squeak on the way down, or squeaking while depressed?
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 11-09-2014, 07:28 PM   #5
Just on the way down.
Old 11-09-2014, 07:32 PM   #6
Then its probably just somewhere along the cable line. You could press and listen for it with the engine off and try to locate it, and if you can reach it, spray silicone lube on it.
Only if you feel like it. Not a major issue or symptom of something breaking.
Sent from my LG-D800 using Mustang Evolution mobile app
Old 11-09-2014, 07:46 PM   #7
Steve96's Avatar
Mine did the same a little lube and it has been fine the past two years
1996 GT
Old 11-10-2014, 03:08 AM   #8
Which spot squeaked? I remember reading about it but i cant remember where.
Old 11-10-2014, 03:25 AM   #9
Not sure exactly where it is yet. I'll look into it better tomorrow.
Old 11-10-2014, 06:43 AM   #10
Could be the plastic quadrant on the way out if its coming from in the car. If not, most likely TOB.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 11-10-2014, 06:46 AM   #11
Pretty sure it's inside the car.
Old 11-10-2014, 12:14 PM   #12
I'd replace the plastic quadrant even if its good. Max Motorsports sells a quadrant/cable/adjuster setup that is top notch and includes an OEM cable. That's another thing, if you have a non OEM cable or aren't sure if the cable you have is OEM or not, its a good idea to replace your cable with an OEM unit. Too many ppl find out the hard way not to use parts store cables.
Old 11-21-2014, 07:11 AM   #13
figures. not long after reading this, now mines making a weird squeak. Most when i push the clutch in, sometimes when releasing. any advice on what kinda lube? just some silicone spray all over? or should i hit a particular spot with white lithium grease?
Old 11-21-2014, 11:07 AM   #14
Replace the plastic quadrant. The older these cars get the more chance of the plastic quadratns getting brittle/cracking/breaking.
Old 11-21-2014, 12:09 PM   #15
Lorraine's driver
ab_mach1's Avatar
If it makes a high pitched bird chirp sound right when you push the pedal in, and it goes away just as fast, that's the TOB touching the pressure plate fingers. The TOB is either not spinning at all or just barely spinning and then it's touching and suddenly spinning fast. Mine does this. It's cool.
Instagram: @ab_mach1
Old 11-21-2014, 02:08 PM   #16
Yea i know the sound my tob makes. This one im pretty sure is comin from the quadrant. Its not like a bird chirp. Not quite a creak either.
Clutch pedal makes squeaky noise galindojr24 2005-2010 Mustang GT 6 10-30-2012 12:37 PM
Squeaky clutch Mike V. Pre-2005 V6 Mustang 6 08-02-2012 09:20 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Vote for Squeaky! (Help me out) WhiteStang99 The Bar 19 02-06-2006 04:38 PM
Squeaky belt? bearing? dont know? Ibanezplayer272 Pre-2005 V6 Mustang 3 03-13-2005 09:07 PM
06:35 AM
