Nitrous Outlet - Mustang Evolution
Old 11-10-2014, 08:58 AM   #1
Slow4V's Avatar
Nitrous Outlet
I was planning on getting a nitrous outlet plate kit for the Mach 1.
What would I need to upgrade ?
- colder plugs ?
- Fuel pump ?
- Dyno tune ?
Any input would be helpful
Planning On 100 Shot.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-10-2014, 11:13 PM   #2
Speed_Mister's Avatar
Region: Arkansas
If your gonna do nitrous or any power adder I would do it right.
•Get some tr6 NGK copper plugs gapped at .035,
•you will need to upgrade injectors, fuel pump, size will depend how much duty cycle they will be at peak horsepower.
•And you can use datalogged email tunes are fine. Same as a dyno tune except you don't see your horsepower and it's cheaper.
•get a window switch, set from 3500rpms to redline, get a purge kit, and a bottle heater for nitrous kit, and you will be 100% safe.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 11-10-2014, 11:16 PM   #3
Region: Arkansas
Not sure what horsepower you are at but I should be around 360~370rwhp and I have 24# injectors and a aviator fuel pump that's "rated" 315lph I think just to give you an idea what size injectors and fuel pump you will need.
Full Bolt Ons
370rwhp 470rwtq
Old 11-10-2014, 11:20 PM   #4
Region: Arkansas
In your tune your a/f at wot should be around 11.5, taking out 3-4 degrees in timing, do NOT spray in over drive gear. Recommend using any nitrous kit except zex. Wideband is highly recommended to watch a/f ratio while spraying and tuning.
Full Bolt Ons
370rwhp 470rwtq
nitrous
Nitrous outlet bottle opener jonathanadams22 1996-2004 Mustang GT 1 07-11-2014 08:47 PM
2012 nitrous outlet kit 125oh 2011-2014 Mustang GT 6 07-28-2013 06:29 AM
Cbad Cars:Back at the Outlet Mall! 5-26-07 rrobello Regional Mustang Discussion 4 05-24-2007 01:03 AM
RPM Outlet. Is It Any Good? danstang Pre-2005 V6 Mustang 22 09-23-2005 10:34 AM
RPM Outlet mustangmike524 The Bar 41 04-14-2005 10:39 AM
06:58 AM
