4.10 gear ratio - Mustang Evolution
Old 11-10-2014, 12:36 PM   #1
Jay180's Avatar
4.10 gear ratio
Can someone explain 4.10 gear ratio and how I can do it to my car and what I will need? I keep hearing about it being one of the best bang for my buck I can do to my car
Jay180 is offline   Reply With Quote
Old 11-10-2014, 01:35 PM   #2
Slow4V's Avatar
It will speed up your rpms , and you will feel it pulling a lot harder.
Not a tech answer but it's deff worth it lol
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-10-2014, 01:37 PM   #3
Jay180's Avatar
What do I need to install?
Old 11-10-2014, 01:44 PM   #4
Take it to a shop.
Old 11-10-2014, 02:27 PM   #5
robin_gt's Avatar
Would it be hard to install gears in the driveway on jack stands with proper tools but no air tools?
robin_gt is offline   Reply With Quote
Old 11-10-2014, 02:44 PM   #6
Slow4V's Avatar
Just get fluid , additive too..
You don't really need to change the bearings unless they are bad.
Get a new crush washer , and that's really it.
It's NOT That Hard To Do The install..But Recommend Taking It To Shop. Install is usually 250-300.
---------- Post added at 03:44 PM ---------- Previous post was at 03:43 PM ----------
Your going to need a 1/2 impact to remove the ring gear and what not.. hand tools would be hell.
Old 11-10-2014, 02:47 PM   #7
If you know how to install it and have all of the proper tools it can be done..... If you have never done it before I recommend a shop
Old 11-10-2014, 06:59 PM   #8
fenixignition's Avatar
for a better answer, its your final drive ratio. they usually reccomend 4.10 for auto transmission. 3.73 if its a manual.
what it does is change the ratio of your gear in your rear axle. id try to explain the relation between your engine rpm and your tire rpm but odds are im gonna get it backward.
as far as what you would feel, youl accelerate faster but your rpms will also rise faster. 2000 rpm on the highway will change from 70mph to somewhere in the 60s. you will need to tune your car so that your speedometer is correct as well.
2002 GT 5sp. 16x,xxx miles
Old 11-10-2014, 07:16 PM   #9
Jay180's Avatar
I have a manual so I'd have to go with the 3:75 then
---------- Post added at 06:15 PM ---------- Previous post was at 06:15 PM ----------
3.73
---------- Post added at 06:16 PM ---------- Previous post was at 06:15 PM ----------
3.73
Old 11-10-2014, 07:42 PM   #10
Billgluckman's Avatar
Keep in mind with 3:73/4:10 gears you're gonna be running a lot higher rpm at higher speed. Be sure you want this before you do it.
The install is not hard. You'll need a dial indicator and know how to use it. Also a torque wrench that measures in inch lbs (as low as 20 I think). And a torque wrench measuring in ft lbs. you'll obviously need a press as well. Most people don't have all of this. If you do, follow the how to on American muscle and get after it.
I just did 4:10s in my 5spd recently. If this was my dd I honestly wouldn't do it though I know a lot of people do.
Billgluckman is offline   Reply With Quote
Old 11-11-2014, 08:04 PM   #11
Jay180's Avatar
Well my mustang is my daily driven car and I want to be decently fast like around 330HP and I kept reading that having a 4.10 gear ratio is the best bang for you buck if you want to mod your car
Old 11-13-2014, 11:37 AM   #12
Slow4V's Avatar
373 are a waste , 410 ftw
Old 11-13-2014, 11:52 AM   #13
You can't go by the whole 3.73 for manual and 4.10 for auto that reliably. And Slow4v has a Mach 1 and revs 1k rpm higher than a GT so 4.10s are better for him.
What i recommend is finding the best rpms for what you want. 4.10s are amazing around down, but at higher speeds you run out of gear quick, i redline 4th at 110, then after that i've got no acceleration. At autocrosses my 4.10s are perfect though, but when i start to do road racing i'll either need a taller tire or i'll need to drop down to 3.73 to get a little more mph out of it.
You will also be revving a lot higher on the highway when cruising. At 80mph i'm at around 2800rpm. That is with a .68 overdrive ratio.
Old 11-13-2014, 12:38 PM   #14
If the rest of my family didnt live almost 200 miles away, then i would have 3.73 in mine. but i also do any non emergency car work over there as well, so i need the gas mileage. as well as being able to go 70mph under 2k rpm so not to piss off the fiance with all the noise. :/
One day though.
Rear gear ratio? 86gt 1979-1995 Mustang GT 5 05-10-2011 11:00 PM
Gear ratio? Joshfelder 2005-2010 Mustang GT 9 03-14-2011 09:03 AM
Tranny gone did use the 2.3 trans on my v8 n likd the gear ratio but now wat to do? Justbust1n 1979-1995 Mustang GT 18 02-26-2011 09:07 PM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 12:31 PM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 08:19 PM
11:33 AM
