Abs light on - Mustang Evolution
Old 11-10-2014, 11:25 PM   #1
1sikdsg's Avatar
Abs light on
About a week a ago the ABS Light turned on my 04 GT and the trac control light turned on as well and can't turn them off. They turn off at times and trac control goes back to normal but lately it's been doing it more often please help
1sikdsg is offline   Reply With Quote
Old 11-11-2014, 04:55 AM   #2
fenixignition's Avatar
go to autozone or advance autoparts. if they are using the good scanner (they should be) then they can pull an ABS code. its probably a wheel speed sensor going bad. the scanner tool should let you know which one. let us know how it goes.
2002 GT 5sp. 16x,xxx miles
Old 11-11-2014, 08:52 AM   #3
Steve96's Avatar
Check your brake fluid level, low can cause the light to come on and off
1996 GT
Old 11-11-2014, 08:56 AM   #4
Wouldnt that be the brake light? Not the abs. Or trac control
Sent from my LG-D800 using Mustang Evolution mobile app
Old 11-11-2014, 09:14 AM   #5
1sikdsg's Avatar
Not the brake fluid that's the rudest thing I checked
Old 11-11-2014, 09:58 AM   #6
Yellastang03's Avatar
Just had the same thing happen to me last week. I was told by 2stang to check and clean abs sensors and connections and it worked.
Yellastang03 is offline   Reply With Quote
Old 11-11-2014, 10:01 AM   #7
come to think of it, when i was replacing a few wheel studs, i noticed some metal particles stuck to the magnet on the wheel sensor. So i could imagine a good cleaning would help improve its signal and effectiveness.
Old 11-11-2014, 10:11 AM   #8
1sikdsg's Avatar
Ima try it first thing when I get off work
Old 11-11-2014, 01:30 PM   #9
Old 11-11-2014, 01:32 PM   #10
Sorry have no idea how I just reposted that.
Old 11-11-2014, 01:37 PM   #11
Before i bought my 01 Bullitt it had the exact same thing. Trac light on and the ABS light on. It turned out to be the ABS module needing to be replaced. I got it from a dealer so they fixed it no extra charge before i took ownership.
That is most likely what is wrong with yours.
Old 11-11-2014, 01:52 PM   #12
1sikdsg's Avatar
Yeah I heard about that but I believe it can be fixed
Old 11-11-2014, 03:48 PM   #13
Steve96's Avatar
My bad. I was thinking brake light not ABS. I Also had to replace a sensor on mine as it was doing the same thing.
1996 GT
Old 11-11-2014, 04:13 PM   #14
1sikdsg's Avatar
Old 12-01-2014, 07:45 PM   #15
02_gt's Avatar
Wheel speed sensor
02_gt is offline   Reply With Quote
Old 12-02-2014, 09:02 AM   #16
XSlashDashX's Avatar
My ABS has been on since I got the car. Traction light doesn't stay on. Comes on like the rest of the lights and then goes off.
abs on non abs sledgehammer General Mustang Discussion 4 01-28-2010 11:30 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
ABS light slick Pre-2005 V6 Mustang 5 04-04-2008 11:31 AM
ABS light Zim 1979-1995 Mustang GT 9 10-13-2006 06:25 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
03:28 PM
