Suspension and tire setup opinion. - Mustang Evolution
Old 11-14-2014, 12:47 PM   #1
phillip433's Avatar
Hey guys. Another opinion post.
I'm just finishing up putting my t56 in my gt. Need something else to invest in so I'm deciding to start on my suspension setup.
I need y'all's opinion on some quality performance tires for street and drag. I don't want drag radials because this is my daily driver. I'm planning on putting 315s on my cobra rims. Yes I'm aware of the stretch but it will be okay. H&r super sport springs with no iso and SVE control arms. I need some shocks and struts too as well as c/c plates. Idk much about the brands on those nor the shocks and struts. Any recommendations or thoughts would be greatly appreciated.
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 11-14-2014, 12:50 PM   #2
Slow4V's Avatar
Tokico HP struts and shocks are great , maximum Motorsports CC plates , full length subframe connectors welded would be good too.
Tires stay away from nitto they are terrible. Mikey Ts make some good street tires.
Sent from my SM-G900T using Mustang Evolution mobile app
Old 11-14-2014, 12:52 PM   #3
phillip433's Avatar
You have mickeys on your Mach?
Old 11-14-2014, 01:58 PM   #4
Mickey Thompson street Comps are going to pretty much be the best non-drag tire to use for street/drag purposes
Old 11-14-2014, 05:02 PM   #5
Steve96's Avatar
What slow said, basically what I have with the hr super sports. Make sure to wrap the springs with something if no isos, so you don't get any unwanted squeaks etc from metal on metal
---------- Post added at 07:02 PM ---------- Previous post was at 07:01 PM ----------
Maximum Motorsports CC plates and don't look back!
1996 GT
Old 11-15-2014, 07:22 PM   #6
phillip433's Avatar
Okay. I'll keep that in mind. Tires ofcourse I want the widest tires. But I have the 17x9 inch termi wheels. Anyone know of putting a 315 size tire on that rim... Will it look unusual since that's a big stretch for the tire?
Old 11-15-2014, 07:25 PM   #7
phillip433's Avatar
And yes. I'm looking at the street comps. I can either choose from 275 or 315 regarding to the width of my rims. But they say the 315 require 10.5 and up. I know it's possible to put it on my 17x9 inch rim just wondering how it would look.
Old 11-15-2014, 07:29 PM   #8
Laquisha's Avatar
Looks good
Old 11-15-2014, 07:30 PM   #9
phillip433's Avatar
Originally Posted by TrevorB3 View Post
Looks good
So it wouldn't be too stretched?
Old 11-15-2014, 07:31 PM   #10
Laquisha's Avatar
Here is the max.
19x9.5 - 285
19x10 - 315
19x10.5 345
Goodluck!
Old 11-16-2014, 12:46 AM   #11
Mile high JDF's Avatar
A 315 on a 9" wheel looks ridiculous, I put some on a buddies car and was not a fan of the look. They bulge out really bad from the wheel. I would go with a 275 on a 17X9
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-16-2014, 12:53 AM   #12
Stuffing a huge tire onto a smaller wheel can also decrease performance over a tire on a proper wheel size. Same exact concept as stretching tires. Just cause the tire is wider doesn't mean it will perform better on that wheel.
Old 11-17-2014, 12:17 AM   #13
phillip433's Avatar
Yea I didn't think it would Benifit much. But I think I'm just going to go with 285
Old 11-17-2014, 10:43 AM   #14
On a 9" wide wheel?
You didn't listen to what I just said.
Old 11-17-2014, 10:47 AM   #15
phillip433's Avatar
I meant 275. Lol. I heard and I understood.
Old 11-17-2014, 11:53 AM   #16
Lorraine's driver
ab_mach1's Avatar
275's are pretty much the biggest tire for 9" wheels. Depending on the tire manufacturer, maybe 285's. The bigger size may fit, but it will look all bulged and ugly if you put tires that are too wide for the wheels.
*Edit
I see others have said the same lol. A good example is my 17x9's. the Goodyear's I had before the BFGoodrich's looked better in 275. The BFG's bulged a little, so it would have probably looked better with 265's.
Instagram: @ab_mach1
Old 11-17-2014, 01:32 PM   #17
255 or 265 is a good width for a 9" wide rim unless you are using Nitto 555s which run narrow. I ran 275/40/18s on my 10" wide rear rim on my 98 and they fit amazingly well. They were BFGs and BFGs run big tho...
Old 11-17-2014, 02:00 PM   #18
275's on Terminator wheels.
They fit perfectly and that's what Termi's came with from the factory.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
ID:	169829   Click image for larger version
Old 11-17-2014, 02:14 PM   #19
bigmac3's Avatar
Here is the max.
19x9.5 - 285
19x10 - 315
19x10.5 345
That's kind of voodoo math isn't it? There is only one inch difference in wheel size but 2.36 inches of tire width difference.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 11-17-2014, 11:30 PM   #20
phillip433's Avatar
I compared my rear 17x9 (275) wheel to my friends 2013 20x9(315) Shelby wheel and my 275 tires were just *** wide as the 315s.
Old 11-18-2014, 05:10 AM   #21
Again it all depends on the make of the tire. My BFG 275s were right about as wide as my old Nitto 315s. Sumis run narrow too. Tirerack has specs for most tires though, that's how I spec'd out my old setup knowing that BFG 235s ran big enough to be nice and flush on an 8" rim without being "hella" flush. And that BFG 275s would fit great on a 10" rim.
You never just go "well this size for this rim or that size for that rim etc...". Different setups, different brands, and generally someone one the interwebs will have tried the combo you are looking to do so google is your friend. I even found some ppl who were running the same 235/275 combo I wanted to do so I could see what it would look like beforehand.
Old 11-18-2014, 10:28 PM   #22
Something i've noticed also is even the tire models of a certain brand may be different. I spec'd out a tire size for my 10" with BFG Rivals, and 295 came out to be the perfect size.
Old 11-18-2014, 10:29 PM   #23
Laquisha's Avatar
Stop being a nerd go to bed college boy. You have like 40 posts a day. lol.
Old 11-18-2014, 10:43 PM   #24
Its only 9:45pm. My first class tomorrow is at 10:30am. Almost 13 hours from now lol.
Old 11-19-2014, 05:10 AM   #25
There are also those of us at work who are on this forum when idle. I work IT right now and if there are no issues or maintenance to be doing... I'm just chilling in response mode for any issues that pop up. When I first took this job, it was a total cluster**** from the person who was before me. Now... pretty much not much to do unless we get new systems in besides showing retards how to enable plug ins after they ***** about how they tried to run a browser 15 times...
Old 11-24-2014, 12:39 PM   #26
mscammed01gt's Avatar
If you put 315 on a 17x9 you will have major bulge. go with a 10 instead
mscammed01gt is offline   Reply With Quote
Old 11-24-2014, 12:41 PM   #27
I'm running 275/35/18 on 18 x9 up front and 305/30/18 on 18x10 in the rear
Old 11-24-2014, 01:18 PM   #28
Again, depends on the brand. A Nitto 555R 315 wide will fit perfect on a 9" rim and be too small for a 10.5" and will be just flush with a 10" rim.
Old 11-24-2014, 01:20 PM   #29
Yes I am aware that but most people aren't willing to pay for Nittos - so they go with a cheaper tire and it creates that ugly bulge.
Old 11-24-2014, 01:48 PM   #30
No, Nittos just run super narrow, nothing to do with cost.
Old 11-24-2014, 02:26 PM   #31
Well, a majority of the Mustang owners I know prefer Nitto - but I have seen a lot of forums talking about staggering and whatnot but they say they just go for an "off brand" since tires are so expensive - then they have to turn around and find different tires because they can't get them onto the rim. I am also aware that all different brands run differently. Me personally I prefer NITTO but my GT came with Continental. I have a set of NITTO at home that are 275 and are about 11 inches wide vs. some off brand tires I have that are 275 and are very close to 12 inches. So I understand for SOME people it may have nothing to do with cost but they wouldn't know how it actually looked with a certain brand unless they tried it, therefore since Nittos are a common 99-04 Mustang tire, it would only make since to go with what you know rather than just going to buy that particular sized tire.
Did you by chance purchase a tire that was "too big"?
Old 11-24-2014, 06:39 PM   #32
No, I've had Nittos in the past and I know from experience that they are overpriced and run narrow. The 555R is not great and is pricey. The 555s are no better than a cheaper BFG. The NT05s are great but are not a DD tire as they wear out real fast. If I was getting a DD tire it would be BFGs or Mickey Thompson Street Comps. For a weekend warrior, NT05s. For a set of drag wheels that sit in the garage to be swapped on for the track, ET streets/big/littles.
Need opinion on exhaust & headers setup dudeitsdylan 2005-2010 V6 Mustang 36 06-04-2012 07:20 PM
Wheel and tire setup Staggered bobsurvives 1996-2004 Mustang GT 12 05-10-2011 03:27 PM
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Solid Rear Suspension Setup Thomas91169 1996-2004 Mustang GT 16 12-27-2006 01:51 PM
best suspension setup for drag BrooksPS Pre-2005 V6 Mustang 2 03-11-2004 09:09 PM
05:51 AM
