Pi intake help - Mustang Evolution
Old 11-16-2014, 01:36 PM   #1
stockstang96's Avatar
Pi intake help
Ok I did a pi intake swap an changed spark plugs an wires my car started twice now it don't wanna start
Sent from my HTCONE using Mustang Evolution mobile app
stockstang96 is offline   Reply With Quote
Old 11-16-2014, 02:00 PM   #2
Billgluckman's Avatar
Codes?
Does it continuously crank or do nothing?
Billgluckman is offline   Reply With Quote
Old 11-16-2014, 02:02 PM   #3
It continuously crank
Old 11-16-2014, 02:41 PM   #4
Go back and carefully re-check all of your work and try to find whatever it is that you forgot to connect or is only partially connected. Pay close attention to the vacuum lines and the air intake.
Old 11-16-2014, 02:41 PM   #5
Did you check all of your wiring connections.
Bigshow14 is offline   Reply With Quote
Old 11-16-2014, 02:43 PM   #6
But it fired right up then I turnt it off it fired up again the I tried a third time no luck
Old 11-16-2014, 02:45 PM   #7
Re-check everything. Especially the vacuum lines and air intake connections.
Old 11-16-2014, 04:25 PM   #8
It could be unrelated to the intake swap. I doubt it, but it could be.
Make sure there is fuel at the rail.
Old 11-16-2014, 09:31 PM   #9
Check your fuses.
COLD AIR INTAKE or SHAKER COLD AIR INTAKE zalizar21 2005-2010 V6 Mustang 14 08-19-2012 07:41 AM
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 11:22 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
12:39 PM
