another v6 v8 swap - Mustang Evolution
Old 11-16-2014, 11:38 PM   #1
irishn8's Avatar
another v6 v8 swap
My 2001 GT automatic (silver) was rear ended and totaled, i bought it back.
Purchased a 2000 v6 manual (white) for super cheap and intend to do the ol' swaparoo.
my question so far is - can i use the t-5 from the v6? is the spline different? im pretty sure i need a different bell housing, where do i get one? hoping to do this swap over the next few weeks.
this is on an extreme budget as much as possible, if i have to get a t-45, i will. i found one for $450. more than i WANT to pay so if the t-5 will work then great!
Old 11-17-2014, 12:07 PM   #2
Lorraine's driver
ab_mach1's Avatar
Midway through 2001's production, Ford started using the TR-3650. Not sure if that changes your situation, but I'm betting the T-5 is specific for the 6's and may not bolt up or not be built to handle the power.
Instagram: @ab_mach1
Old 11-17-2014, 12:40 PM   #3
irishn8's Avatar
yes, in february of 01 they switched to the tr3650.
the t-5 can bolt to 4.6 blocks with the first two casting codes of the windsor blocks made in 94 and some 95s. after that they went to a different bolt pattern with the romeo blocks.
think im just going to get a t-45 or tr3650 so i dont have to worry about the t-5 breaking on me.
Old 11-17-2014, 12:45 PM   #4
Wrong, the T-5 will not bolt to a modular without a $600+ Quicktime bellhousing. The 4.6L bolt pattern is completely different from the pushrod 5.0 bolt pattern. Oddly enough, the old 5.0 and the 3.8L V6 share the same bolt pattern. Long story short, you need a T45 or 3650.
Or just leave it automatic and put in a nice stall converter while its out and j-mod it and be faster than if you converted to 5 spd.
Old 11-17-2014, 12:52 PM   #5
irishn8's Avatar
List of Ford bellhousing patterns - Wikipedia, the free encyclopedia
the early 4.6s shared a bolt pattern with the 3.8 and the 5.0
the white car is already set up for manual although to switch to a t-45 i would have to convert other things too, the tranny mount, reverse light switch and who knows what else.
Old 11-17-2014, 01:08 PM   #6
There are other "gotchas" to those engines. Let me clarify... they will not bolt to any 4.6L blocks from a Mustang. You'd spend way more money trying to find a 4.6L that old that still runs and then adapt it to your application than you would just buying a T45.
Those motors also weren't in Mustangs, F1 and F2=1991 and 1992.
It also might be cheaper for you to just sell everything you have and buy a GT. Might not be, but they can be had for not very much money.
Old 11-17-2014, 01:11 PM   #7
irishn8's Avatar
so i went ahead and ordered a tr3650, what all would i need to do to the white car set up for a t-5 getting a 4.6l? im guessing ill need a fly wheel? or will the flywheel of the automatic work? i know ill need a clutch kit, polot bearing, throw out bearing. anyone know if the mount for the t-5 will fit the tr3650? if so i can just move it back as needed to fit.
Old 11-17-2014, 01:21 PM   #8
bigmac3's Avatar
...It also might be cheaper for you to just sell everything you have and buy a GT. Might not be, but they can be had for not very much money.
I just picked up a nice '02 GT for $4.7K.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 11-17-2014, 01:21 PM   #9
irishn8's Avatar
well it certainly would be much easier but not cheaper. GT automatics around here go for at least 5k in good condition, GT manuals go for around 7k in stock good condition. the value of my totaled GT is worth $1k, the i got the v6 manual for $1800.
Old 11-17-2014, 01:28 PM   #10
Autos don't have flywheels, they have flexplates. You will need the $130 6 bolt iron Ford flywheel, a clutch, all the 5 spd swap parts. Mount is going to be different so you'll need that too. 3650 uses a different shifter so you need a 3650 shifter, new driveshaft since the 3650 is 31 spline output and the t-5 is 28 or you can find a 31 spline manual trans yoke and put it on the driveshaft from the auto.
Like I said, might be cheaper to sell what you have than do this conversion but I don't know for sure what you spent so that'd be up to you to decide. I would also be VERY wary of buying a used 3650, its more of a crapshoot than other transmissions because they all came overfilled from the factory and this caused windage problems with them until the TSB was released to drop the fill from 3.8 to 3.2 quarts.
Old 11-17-2014, 02:06 PM   #11
irishn8's Avatar
if its too much to use a tr3650, ill just make it an automatic, that cant be that hard since i already have everything.
Old 11-17-2014, 02:39 PM   #12
You already have everything to put together an automatic GT. That is the route I would go. J-mod the trans while its out. J-mod is a cheap mod that'll make the trans shift like a BAMF. I'd also look into a converter. That's $400-$600 you probably weren't looking to spend but if you are looking to go fast in a straight line, it'll really help.
Old 11-17-2014, 02:45 PM   #13
irishn8's Avatar
ya guess ur right
Old 11-17-2014, 02:49 PM   #14
I mean do what you want man, if you want a 5 spd do it, but just be aware of the costs involved before you make the decision. Like a tune for the auto computer to get rid of all the auto stuffs etc... As I said it would very likely be cheaper to just buy a 5 spd GT after selling your stuff seeing but you'd have to see what's out there. It has been my experience that v6-v8 swaps are almost never cost effective for a first timer.
Old 11-17-2014, 02:51 PM   #15
irishn8's Avatar
i have a tuner so telling the computer it now has a manual is not an issue.
Old 11-17-2014, 02:58 PM   #16
irishn8's Avatar
u know what, i like automatics, you can tune the crap out of them. having a manual is more of a novelty to me, plus manuals sell for more.
Old 11-17-2014, 03:00 PM   #17
Autos are better for 1/4 and light to light anyway. Anyone who tells you different has never been to a track.
Old 11-17-2014, 03:04 PM   #18
irishn8's Avatar
i agree, humans make mistakes automatics dont
Old 11-17-2014, 07:24 PM   #19
V6 stang's Avatar
Yep... 8k for my 116k manual...
Yes I edit my posts a lot, auto correct likes to sabotage me!
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 11-18-2014, 05:40 AM   #20
I saw a 2002 GT automatic on Autotrader with 28k miles for $9k a few months ago... I also paid $6k for my very well modded and PI swapped 98GT when I bought it with less miles than that. I'd say you overpaid unless you are in Cali or something. Seems that in those areas the market is so nuts that it is cheaper to buy a few states over and go fly out/drive back or have the car shipped.
Old 11-18-2014, 07:50 AM   #21
V6 stang's Avatar
Texas. 8k is with ttl but I didn't overpay. There are deals here and there but that's what they go for around here. Auto's are a little cheaper. I assume it's because we can drive them a lot longer than in the north. Makes them worth more.
Roush Exhaust
Old 11-18-2014, 07:53 AM   #22
irishn8's Avatar
another v6 v8 swap
Thats actually a myth, i know it makes sense that way but strangely enough its not true. Somehow theres more rust in Texas than Washington state, I've seen both junk yards.
Also, getting a car from a dealer is overpaying, i always buy cars from craigslist and save tons, but i also fix my own cars and know what I'm looking for.
Old 12-12-2014, 03:35 PM   #23
irishn8's Avatar
Progress report..
almost half way done, we are going to lift the body up and extract the drive train from underneath.
---------- Post added at 02:35 PM ---------- Previous post was at 02:34 PM ----------
Progress report..
Old 12-22-2014, 02:56 PM   #24
irishn8's Avatar
So...ya im havin fun
Another day, another problem SixBanger General Mustang Discussion 69 03-05-2014 11:40 AM
Another Year, Another USC FAIL!!!!!!!!!!!!!!!!!!! Brent The Bar 20 09-27-2008 07:08 PM
Another killer eBay find - unique 4g63 swap, this is for you Thomas fast64 The Bar 2 01-16-2008 07:51 PM
another engine swap question blk99stang Pre-2005 V6 Mustang 5 02-20-2006 06:19 AM
Well, I got another car, guess I won't be getting another stang anytime soon :(. Rick0636 The Bar 12 09-25-2005 10:10 PM
03:35 AM
