Drill an tap - Mustang Evolution
Old 11-17-2014, 02:12 PM   #1
stockstang96's Avatar
Drill an tap
Can I drill an tap my pi intake without taking it back off
Sent from my HTCONE using Mustang Evolution mobile app
stockstang96 is offline   Reply With Quote
Old 11-17-2014, 02:29 PM   #2
Tyoung68's Avatar
What are you drilling and tapping on it? As long as you dont get metal shavings anywhere near the inside of your engine then itll be okay. But probably a good idea to take it off
Killing time isnt murder, it's suicide
Old 11-17-2014, 03:25 PM   #3
Cbird's Avatar
Region: Iowa
He probably did a PI swap and has two coolant sensors instead of the 1 sensor that the 99-04s had.
I would take it off. I don't see any other way to drill and tap without getting plastic shavings into the motor.
Cbird is offline   Reply With Quote
Old 11-18-2014, 08:04 PM   #4
This is what I had to do to mine. Unless you want shavings all in your coolant system, you need to pull the crossover off. When you do, you may wish you had bought a new intake if you got one secondhand. I would never recommend buying a used PI intake after seeing what years of heat cycles does to the plastic underneath the tstat.
Drill bit is 9/16 btw, you don't go right to that, work up to it in stages. Tap is a 3/8 -18 NPT which you can get cheap from Harbor Freight. I also highly HIGHLY suggest using a drill press.
Drill & Tap Size for GT40 Intake Hellish Horse 1979-1995 Mustang GT 9 10-09-2014 06:38 PM
Craig's Custom Mustang Brackets - DONT DRILL for your front L/P TrentonPhoenix 2005-2010 Mustang GT 0 08-14-2012 01:32 PM
25/64 drill bit for the boss front splitter?? Edens5 2011-2014 Mustang GT 2 04-20-2012 04:21 PM
Cordless Drill used on Ricer 00vertstang Pictures and Videos 3 02-10-2007 12:31 PM
got a $30 drill bit today whipster24 The Bar 9 11-28-2004 09:44 PM
03:12 PM
