Lowering? - Mustang Evolution
Old 11-17-2014, 06:33 PM   #1
02_gt's Avatar
Lowering?
What's a good way to go about lowering ur car I'm thinking about just using springs but others have said coil overs
Sent from my HTC6525LVW using Mustang Evolution mobile app
02_gt is offline   Reply With Quote
Old 11-17-2014, 07:24 PM   #2
Geiger's Avatar
If you just going for looks and want to keep the budget reasonable, a good set of springs will do. If you trying to race, then coilovers
Sent from my SCH-R950 using Mustang Evolution mobile app
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 11-18-2014, 03:23 AM   #3
02_gt's Avatar
Alright appreciate it do you know if the ones from American muscle good
Old 11-18-2014, 04:36 AM   #4
Geiger's Avatar
Personally I've had. Tein, h&r, and 2 sets of Eibach. No complaints out of any of them. I've head that the SR springs are good bang for the buck. No experience with them personally though.
Old 11-18-2014, 06:52 AM   #5
The_Chech's Avatar
Lowering?
Well first I have to ask what are looking to get out of lowering the car? Are you trying to get rid of some of that fender gap or gain some handling or even getting a drag set up? There are so many types of suspensions you can run these days it's really all on what your looking to get out of your suspension
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 11-18-2014, 09:22 AM   #6
Steve96's Avatar
Get the H&R supersports from AM, maximum motorsports CC plates, Tokico HP shocks and struts, new poly isolators, possibly new ball joints (moog or upgrade to Steeda ) good time to do ball joints anyway. If your just going for looks and a little performance improvement then this will work out. There are tons of different manufacturers, and set ups you could go with. I would suggest getting a heavier duty shock/strut set up when you put the new springs in to handle the drop. Also the CC plates will be needed to get you back into spec when you get aligned.
1996 GT
Old 11-18-2014, 09:41 AM   #7
Billgluckman's Avatar
I lowered mine with eibachs pro kit. It rode fine until you got on rough roads then it was just horrible. Ended up pulling them and going back to stock height.
Billgluckman is offline   Reply With Quote
Old 11-18-2014, 09:43 AM   #8
Eric5oh's Avatar
SR performance springs from AM w/ any panhard bar will lower the car nicely while still managing normal driving habits
Eric5oh is offline   Reply With Quote
Old 11-18-2014, 09:57 AM   #9
Geiger's Avatar
Lol Bill Gluckman. He's down with the b*tches and hoes lmao
Old 11-18-2014, 10:25 AM   #10
Lorraine's driver
ab_mach1's Avatar
Keep in mind that usually you want to upgrade the shock and struts when you lower your ride. You can match up a nice set with the springs and the ride won't be so bad. You might be able to get away with the SR springs as their stiffness is right around where the stock GT's are. The down side is that they aren't real stiff so you might bottom out more. Usually when you lower it though, you want a bit better handling, which means you want stiffer springs.
Instagram: @ab_mach1
Old 11-18-2014, 10:26 AM   #11
Old 11-18-2014, 11:53 AM   #12
The_Chech's Avatar
This right here will be an amazing setup. I ran the H&R springs my self before I switched to coilovers.
Old 11-18-2014, 12:19 PM   #13
02_gt's Avatar
Yeah the gap a looks
Old 11-18-2014, 12:30 PM   #14
The_Chech's Avatar
Well the lower you go the more involved it becomes to make it work. For some what of a decent drop H&R springs lower it 1.6 in the rear and 2" in the front and have a good ride quality because they are a progressive spring. Tein Springs will drop it more to about 2.3 in the rear and 2.5 in the front. Steeda ball joints will also lower the front .5 if you don't use the spacer for out under the spring when installing the ball joints.
If you don't want that much of a drop then I'd look at eibach.
To give you and idea of what a 3.5" drop looks like Click image for larger version
Name:	ImageUploadedByMustang Evolution1416338956.966874.jpg
ID:	169888Click image for larger version
Name:	ImageUploadedByMustang Evolution1416338977.005342.jpg
Old 11-18-2014, 12:36 PM   #15
02_gt's Avatar
Yeah that's low lol I was wanting about 1.5 all around or 2
Old 11-18-2014, 12:39 PM   #16
Lorraine's driver
ab_mach1's Avatar
Pretty sure the H&R Super sports and race springs are NOT progressive rate springs.
2004 Azure Blue Mach 1
IG: @azurebluemach
Old 11-18-2014, 12:39 PM   #17
02_gt's Avatar
There's not much of a gap
Old 11-18-2014, 12:41 PM   #18
The_Chech's Avatar
Trust me if you like the lowered look id go for atleast a 2" drop. You won't scrape as much as me, if any because I have roush's body kit and side exhaust. And I put my K member through hell being this low. A friend of mine has his lower with Steeda springs at 1.5 and regrets not going lower. I'd suggest H&R or Tein S for springs and get some nice springs and struts and Maxium Motorsports Caster Camber plates.
Old 11-18-2014, 12:41 PM   #19
Lorraine's driver
ab_mach1's Avatar
OP, if it's mainly looks, I think I try the SR springs and see how the ride is. You might be able to get away with using new camber bolts for your alignment. They sell those on AM too. Might get lucky and not need CC plates with these springs.
IG: @azurebluemach
Old 11-18-2014, 12:45 PM   #20
The_Chech's Avatar
IG: @azurebluemach
Your right they may be a dual rate springClick image for larger version
Name:	ImageUploadedByMustang Evolution1416339903.802143.jpg
Old 11-18-2014, 12:45 PM   #21
02_gt's Avatar
Alright I appreciate all the help. How do you set a profile pic it never works
Old 11-18-2014, 02:58 PM   #22
The_Chech's Avatar
Of your using a picture already and it's not working you may have to crop it and make it smaller for it to work
Old 11-18-2014, 03:33 PM   #23
02_gt's Avatar
Alright if I go 2" would I have to worry about tires rubbing
Old 11-18-2014, 03:53 PM   #24
The_Chech's Avatar
It really depends on what wheel and tire you have but I highly doubt you will unless you have spacers and some low offset wheels
Old 11-18-2014, 03:58 PM   #25
The_Chech's Avatar
Even at 3.5" drop and coilovers I don't rub but I had to roll my fenders to clear Click image for larger version
Name:	ImageUploadedByMustang Evolution1416351482.984820.jpg
Old 11-18-2014, 04:07 PM   #26
02_gt's Avatar
Ok I have 18x9 saleen style wheels
Old 11-18-2014, 04:14 PM   #27
The_Chech's Avatar
Yeah you'll be fine your offset is plenty
Old 11-18-2014, 04:15 PM   #28
02_gt's Avatar
Alright I sure am glad I found this app lol it's been a ton of help
Old 11-18-2014, 04:20 PM   #29
Figured i'd chime in....
If you plan to drop 1.5" or less then you will be fine with SR springs and Camber bolts.
If you are looking for the 1.5-2" range then go with a set of H&R Super Sports or Eibach Pro Kits with Caster Camber plates. This will be the best option for most that are looking for a great ride height as well as increased handling. At this point upgraded shocks and struts are HIGHLY recommended.
If you want to go really low (safely) and have awesome performance then a set of coilovers is what you need. They not only handle better than the regular spring set up, you can adjust their height to how you want it.
Old 11-18-2014, 04:23 PM   #30
My car is on coilovers currently. I decided to just forget about springs, shocks, and struts and go with the big boys. Handles unlike any normal spring will be able to, and the height is adjustable. I haven't measured yet exactly how much lower than a regular GT it is. I just found a ride height i like.
ID:	169903   Click image for larger version
Old 11-18-2014, 04:29 PM   #31
02_gt's Avatar
That's sweet I just don't have the money for coil overs every set I found are over 800$
Old 11-18-2014, 04:37 PM   #32
Steve96's Avatar
Look at the racelands I believe the chech used these. I think their under 500 for the set.
1996 GT
Old 11-18-2014, 04:39 PM   #33
The_Chech's Avatar
Racelands coilovers are 570$ shipped to your door and will take just as much time to install as springs give or take an hour. How ever they are non-dampening in the front. Meaning you can't make the ride softer or harder. I have them and they work far better then my H&R spring setup. Not as good as Soccers Maxium Motorsports setup though.
Old 11-18-2014, 04:41 PM   #34
02_gt's Avatar
Alright I'll check them out
Old 11-18-2014, 04:58 PM   #35
fomoco4life's Avatar
Anyone have any old lowering springs they with wish to sell me?
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
10:46 PM
