Water temp issues. - Mustang Evolution
Old 11-17-2014, 11:51 PM   #1
ward.r's Avatar
Water temp issues.
Ok so over the weekend i replaced my heater core. Not to bad of a job got it done in around 3 and a half hours doing it alone. So i started it heat came through jus as it should. Went for a drive the car got about half way to normal operation temp then lost all water temp back down to cold. What would be causing this? It did it again tonight had it fully warmed up started driving and then by time 10 mins was up my water temp was down to nothing
Sent from my SPH-L300 using Mustang Evolution mobile app
ward.r is offline   Reply With Quote
Old 11-18-2014, 03:08 PM   #2
EastTNMustang's Avatar
You may have something lodge in the thermostat...probably dislodged some gunk when you changed the heater core and now it's holding the thermostat open.
EastTNMustang is offline   Reply With Quote
Old 11-19-2014, 05:42 AM   #3
ward.r's Avatar
Ok i thought it could be the thermostat but wasn sure due to the only time i lose water temp is while driving
Old 11-19-2014, 06:12 AM   #4
Yes, sitting still with the engine running you would see a rise in temp, even with the thermostat stuck open...once you start moving you have a large amount of air flowing thru the radiator and cooling down your coolant, especially if it's cold where you live
Old 11-20-2014, 02:00 AM   #5
ward.r's Avatar
Ok i jus wanted to be sure thats the most logical reason its been doing that. Kinda cold losing heat at -5ยบ out
Old 11-20-2014, 05:48 AM   #6
bucko's Avatar
Also, make sure there are no air pockets in the cooling system. Sometimes parking the nose higher than the rear can aid in "burping" ther cooling system. After a few warmups and shutdowns, the air should remove itself, as the radiator will draw from the overflow tank if the air pocket pushes its way back to the radiator, assuming there are no leaks in the system.
Water temp - Thermostat & Head Temp ArtU 2011-2014 V6 Mustang 3 07-19-2013 09:30 PM
IEQUUS water temp gauge , glow brand new mac sk Mustang Parts for Sale and Wanted 3 04-26-2007 07:33 AM
Decided to keep Water Temp Guage Ibanezplayer272 1979-1995 Mustang GT 2 02-04-2006 05:52 PM
Autometer Pro-Comp Ultra Lite Water Temp Gauge Ibanezplayer272 Mustang Parts for Sale and Wanted 0 01-30-2006 03:01 PM
Autometer Lunar Water Temp Gauge FS stangin99 Mustang Parts for Sale and Wanted 0 05-16-2005 05:11 PM
11:33 AM
